HELP A&R Instructions - Kawasaki ZX-10R.net
post #1 of 8 Old 05-13-2007, 09:38 PM Thread Starter
I bought some A&Rs a while back. Haven't had time to put them in and now I can't find the link to the instructions . I've searched on this site for about the last hour. Thanks
Bobbys1967 is offline
post #2 of 8 Old 05-13-2007, 10:05 PM
JD81's Avatar
I can't find the link in my email inbox, but I'm sure you could get them to email it to you.
JD81 is offline
post #3 of 8 Old 05-13-2007, 10:17 PM
Speed Freak
garth285's Avatar
what are A&R's????
garth285 is offline
post #4 of 8 Old 05-13-2007, 10:20 PM
bluedevil's Avatar
Originally Posted by garth285 View Post
what are A&R's????
Good question, I figured if I don't know what A&Rs are then I most likely don't have the instructions.
bluedevil is offline
post #5 of 8 Old 05-13-2007, 10:21 PM Thread Starter
what are A&R's????
A&R Exhaust baffles. There are a lot of posts on them. I emailed them and I'm sure they will send me the link again, but I thought I might find it on here faster
post #6 of 8 Old 05-13-2007, 10:24 PM
Speed Freak
garth285's Avatar
ooooo ok, sorry cant help, havent worked with them.
garth285 is offline
post #7 of 8 Old 05-13-2007, 11:15 PM
joedirt199's Avatar
hell you dont need any instructions. i did my buddies r1 without them. you planning on making the mufflers a tad shorter? cause if so cut the muffler with a hack saw just behind the end cap. dont cut all the way through but just through the titanium outside. if you want to keep them the same size drill out the rivets in the end cap. dont drill too big. 3/8's or just a shade larger will work. when you get the cap off there is most likely four weld spots holding the end pipe to the titianium cover. drill those out. just to let you know that drilling welds is a pain in the arse so that is why we opted to shorten the cans just a tad. when you drill out the welds put the end pipe in a vise and tap on the mounting bracket with a rubber mallet to separate the inards from the outards. your muffler should be totally empty. now take your baffles and wrap them with the insulation, put that nylon stuff towards the inside and take some masking tape to hold the insulation together long enough to get them back in the muffler. slide baffle and insulation into muffler and replace end cap. put rivets into the holes. if you cut the muffler drill through the end cap and rivet it on. repeat for second muffler. i have the a&r baffle for my 05 that i will be installing soon. good luck.
Is this where you wanna be when Jesus comes back?
Flags and handlebars should never touch the ground.
GOD made Police so Firemen would have HEROES
MODS: Homemade 1/5 throttle, -1+2 gearing, R1 Master Cyl, Galfer S/B Brake lines, 954 Handlebars, GSXR stock damper, ZX14 mirrors, gutted/shortened/ceramic coated stock exhaust, Hotbodies D/B, Ramair tube brackets, Speedohealer, flush front signals, Fake Sato rearsets, FZ1 Brembo rear master cylinder, Fender eliminated...
joedirt199 is offline
post #8 of 8 Old 05-14-2007, 07:56 AM
zx10x2's Avatar
Images: 19
Send a message via Yahoo to zx10x2
Here ya go:
http://aandrmufflers.com/ZX10RInstructions.html
- 90 Mustang Coupe - 578 hp Grocery Getter
- 06 ZX-10 no mods - I love it
- 10 F250 Crew Cab
- 08 F-450 Crew Cab
I HAD A HANDLE ON LIFE, BUT IT BROKE OFF
zx10x2 is offline
06 10R TRE Install Instructions BigDally Performance and Tech 42 08-03-2006 09:14 AM
06 10R speedohealer instructions sewman Performance and Tech 2 05-31-2006 05:31 PM
TRE Instructions crispin Performance and Tech 1 07-22-2005 11:54 AM
Sho Gun slider instructions NWZX10 Performance and Tech 26 03-16-2005 10:10 PM
