Help please... - Kawasaki ZX-10R.net
post #1 of 16 Old 03-07-2008, 03:12 PM Thread Starter
kawiiiiii's Avatar
Images: 19
Help please...
Ok, here is my problem. For the second time, my bike started shutting off while riding like an electrical problem. I found out that when the idle control knob touches ground or metal to metal, it causes the engine to shut off.
First I like to ask you if anybody had similar problem, second if somebody can be nice to try and see if their bike dose the same thing.
Any help or input would be appreciated.
kawiiiiii is offline
post #2 of 16 Old 03-07-2008, 03:47 PM
JOSHUAZX10's Avatar
Images: 7
Send a message via Yahoo to JOSHUAZX10
Isn't your idle control wrapped with a plastic knob on it?? I don't see how it could short unless for some reason you have metal sticking out somewhere...
JOSHUAZX10 is offline
post #3 of 16 Old 03-07-2008, 03:51 PM
JOSHUAZX10's Avatar
Images: 7
By the way, you sure it isn't your kickstand switch not working properly?? Follow the 2 wires from the switch up until you find the bullet connectors (if our bikes have them), then unplug them and plug them into each other so the switch is not in use and you can still go riding to test it out. If it doen't do it anymore it's your switch...Could be other things though
post #4 of 16 Old 03-07-2008, 03:54 PM Thread Starter
kawiiiiii's Avatar
Images: 19
My front sprocket cover is out and it can touch the metal gaurd around the chain and sprocket. But that is not the problem itself maybe part of the problem. I wanted to know if that is the case for other people or there is a short causing that I should look for that.
thanks for posting.
post #5 of 16 Old 03-07-2008, 03:59 PM Thread Starter
kawiiiiii's Avatar
Images: 19
By the way, when the bike started to shut off every time I hit the throttle, hard front break helped. So I believe something is loose.
I will check the stand too.
post #6 of 16 Old 03-07-2008, 03:59 PM
JOSHUAZX10's Avatar
Images: 7
thanks for posting.
shouldn't be a part of the problem unless your idle knob/shaft itself is made of metal, but I think they're sleeved in plastic...or should be
post #7 of 16 Old 03-07-2008, 04:02 PM
JOSHUAZX10's Avatar
Images: 7
Sounds like the switch, especially if it's happening when you hit the throttle. Try what I said in my 2nd post, shouldn't take more than 10 minutes...
post #8 of 16 Old 03-07-2008, 04:04 PM
JOSHUAZX10's Avatar
Images: 7
One other thing you could try first is going for a little ride and putting pressure upward on the kickstand itself when hiiting the throttle. It could be loose and lowering just enough to trigger the switch when you accelerate...ok, I think I'm done
post #9 of 16 Old 03-07-2008, 04:05 PM Thread Starter
kawiiiiii's Avatar
Images: 19
Thanks I will. But can you be kind to check and see if your bike suts off when ground the knob?
post #10 of 16 Old 03-07-2008, 04:10 PM
JOSHUAZX10's Avatar
Images: 7
I would if I wasn't 100% sure that my plastic sleeve and plastic knob wouldn't cause a short...I'm not home right now but if no one else helps you before then I'll check when I get home
