help: pc3 wont power up! - Kawasaki ZX-10R.net
post #1 of 19 Old 05-31-2007, 02:07 PM Thread Starter
inappropriate
hesaves0211's Avatar
Images: 67
i bought a used pc3 from a fellow member. when i tested the pc3 w the 9 volt it had no prob powering up and linking to my laptop were i could retrieve its current map. however, once plugged into the 10s harness it will not power up (flash its little lights) independently. worst yet when i would start the bike it would turn over then immediately cut the motor. the "FI" light is also illuminated during this time. i could twist the throttle to give it gas but that would only result in a mess of smoke and rough operation. when i removed the pc3 and reconnected everything as it was the bike will operate fine.
i removed the unit, inspected all pins and wires and reinstalled. no luck yet, same symptoms as my first attempt.
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #2 of 19 Old 05-31-2007, 02:10 PM
luckz88's Avatar
Send a message via AIM to luckz88 Send a message via Yahoo to luckz88
unhoook everythign and put it back to stock and see if you bike starts and runs fine than...it may have been damaged in shipping
NESBA #88
Madness Racing wishes he could handle the power of a GSXR
All my homies left this site
luckz88 is offline
post #3 of 19 Old 05-31-2007, 02:16 PM Thread Starter
inappropriate
Images: 67
i was afraid of that. isnt there a way to reset it?
post #4 of 19 Old 05-31-2007, 02:17 PM
usman's Avatar
Images: 13
silly little thing, on the pc3... on plug goes right into the fuel rail, and the 2nd plug gets the connection to the old plug that was going to your fuel rail, i think its brown.
i know i was a retard. and did it wrong.. i plugged one forgot to plug the other and had the same FI light issue.
old man ran off on his wheelchair
theazzman.com (my blog)
usman is offline
post #5 of 19 Old 05-31-2007, 02:32 PM Thread Starter
inappropriate
Images: 67
can you clearfy? i cant quite make out what your saying.
post #6 of 19 Old 05-31-2007, 02:45 PM
mjg68901's Avatar
Make sure you have the pc hooked up correctly is what he is saying. If the connectors are switched around or not plugged in correct this could be the result you are seeing.
http://www.racemph.com/
Heavenly Father, thank you for your Word which is the Truth that sets me free. Give me strength to separate myself from anything that does not honor You. In Jesus Name. Amen.
mjg68901 is offline
post #7 of 19 Old 05-31-2007, 02:52 PM
mjg68901's Avatar
Try this....
http://www.kotiposti.net/strato/Power%20Commander.htm
mjg68901 is offline
post #8 of 19 Old 05-31-2007, 02:56 PM Thread Starter
inappropriate
Images: 67
Originally Posted by mjg68901 View Post
if im not mistaking thats a second gen. im working w first gen. i dont think you can get mixed up i didnt see anyother harness but ill triple check
post #9 of 19 Old 05-31-2007, 03:02 PM
mjg68901's Avatar
What year are you working with? People have had problems getting the connectors swapped around. I believe this is the bike(2005) that the description was written off of.
http://www.kotiposti.net/strato/Wint...20-%202006.htm
Make sure your ground is good also.
mjg68901 is offline
post #10 of 19 Old 05-31-2007, 03:10 PM Thread Starter
inappropriate
Images: 67
this is the two connectors i was working with.
wont start 10roller Performance and Tech 5 05-08-2007 06:44 PM
bike wont rev out streetfighter Performance and Tech 4 11-22-2006 08:02 PM
help power commander issues wont run properly red fi light is on streetfighter Performance and Tech 17 11-12-2006 01:56 PM
Anaconda...You wont believe it 'less you see it. hillcountry10r Pictures and Videos 25 04-20-2006 07:45 PM
