Help on PC111 usb locked - Kawasaki ZX-10R.net
post #1 of 13 Old 08-25-2008, 05:35 AM Thread Starter
TINMAN's Avatar
Hi guys I was wondering if anyone could help me on un-locking my PC111
I installed the powercommander on my 2005 zx10r quite easy really turn the ignition after it was installed and the lights on the commander did come on.
So I thought Maybe it didn't have a map in it, Put a 9volt battery to the pc3 loaded a map into it which seems like it was taking ages, After the hour it still haven't loaded up so i decided unplug it and try again!
Now all it's says is pc3 is locked
Can anyone Help Please!
TINMAN is offline
post #2 of 13 Old 08-25-2008, 10:53 AM
dirt ninja's Avatar
Images: 9
call powercommander. They will definately help you out. Worst case scenario would be you taking the commander out and sending it to them to unlock if you cant get it done over the phone with them.
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
post #3 of 13 Old 08-25-2008, 04:40 PM Thread Starter
TINMAN's Avatar
I live in Sydney Australia and have emailed them with the problem over a week ago and the still haven't got back to me.
So I'm a little stuck
TINMAN is offline
post #4 of 13 Old 08-25-2008, 04:43 PM
.net Most Followed Member
luis.pita's Avatar
have u called them, or even re-install it? u bout that pc where?
luis.pita is offline
post #5 of 13 Old 08-26-2008, 10:17 AM Thread Starter
TINMAN's Avatar
TINMAN is offline
post #6 of 13 Old 08-26-2008, 11:06 AM
mdzx10r's Avatar
It will need the programmer box, some shops may have one. It is used when doing firmware updates and such. We had to use it on a buddies ZX14.
mdzx10r is offline
post #7 of 13 Old 08-28-2008, 01:46 AM Thread Starter
TINMAN's Avatar
Thank you for your help
TINMAN is offline
post #8 of 13 Old 09-03-2008, 04:13 PM
six2one's Avatar
what you need is the PCPROG like the guy said above. i have one...it seems its just a serial to USB converter (i could probably make one) its 40.00 from dynojet (in american funny money that is). it will come with the power adapter and a usb cable and the pcprog and a mini-cd (yes, the small ones) of the dyno jet utils in a flash (as in web) based utility that will allow firmware upgrades and what not. you didnt happen to try a firmware upgrade on this did you? cause certain firmwares cant be flashed via usb (or it will brick) and you need to use the pcprog. also, it cant be flashed when the bike is running (durr ta durr).
post back if your still having trouble cause ive been down this shitty road before. i know ill get flamed, but PCIIIs suck...one thing i miss is my zukies reflashable stock ECU. the stock ecus almost never dump.
but its probably a good idea for you to get the pcprog anyways...it will save your ass sometime i bet (and others too) i know mine did.
six2one is offline
post #9 of 13 Old 09-03-2008, 05:05 PM
Speed Freak
garth285's Avatar
can anything come up on the power commander,. I know that if you can get anything to come up if you hit the TOOLS and then the ENVIRONMENT OPTIONS and then you press CTRL + R a reset button should show up... I dont know if you can get that far but maybe try it???
garth285 is offline
post #10 of 13 Old 09-03-2008, 05:22 PM
luis.pita's Avatar
is it fixed yet Thien?
2006-2007 PC111 4 sale rojapar Parts, Gear and Accessories 3 11-06-2007 03:11 PM
zx10r pc111 map rroobb Performance and Tech 1 03-18-2007 04:36 PM
pc111 rojapar Performance and Tech 6 09-18-2006 09:42 PM
