Help me Adjust Susp To My Weight - Kawasaki ZX-10R.net
post #1 of 6 Old 05-31-2007, 03:31 PM Thread Starter
HI, GUYS,
I NEED A HAND, TO ADJUST THE SUSP TO MY WEITH...
WHT DO YOU THINK , IS THE BETTER CONFIGURATION TO MY WEITH, 95 KGs FOR MY ZX-10 07.....
THANKS FOR ALL ¡¡¡¡
ILU2792 is offline
post #2 of 6 Old 05-31-2007, 03:36 PM
CMG
what kind of riding are you doing ?
is 95 KG with all the gear ? ( track suit shoes, helmet etc )
I believe you will need to get stiffer spings (1.0 kg )
CMG is offline
post #3 of 6 Old 05-31-2007, 03:41 PM Thread Starter
Ahh, No,
With All The Gear It Colud Be Around 100 Kg, And I Wat To Change De Susp. Setup To My Weith,,,
The Ride Is Sport Tourist,,,, Not For A Track----
Thanks ¡¡¡
ILU2792 is offline
post #4 of 6 Old 05-31-2007, 03:44 PM
Cling's Avatar
You need stiffer springs, and about 35mm of travel on the front and about 30mm travel in the rear when you sit on the bike with gear for touring.
Cling is offline
post #5 of 6 Old 05-31-2007, 03:47 PM
BANNED
ZX10Rracer's Avatar
1st set you rider sag "forks" 35mm from full ex, "shock" 30mm from full ex ..you want 20 mm of free sag {no rider} in the front and 10mm in the rear....you may need to re-spring both.
ZX10Rracer is offline
post #6 of 6 Old 05-31-2007, 03:55 PM
mjg68901's Avatar
You can use this to start from.
http://www.sportrider.com/tech/suspension/
Use this as a guide or whatever you want. Scroll down and there are settings for a '06 ZX-10r.
http://www.sportrider.com/bikes/146_...gs/index5.html
Hope this helps.
http://www.racemph.com/
Heavenly Father, thank you for your Word which is the Truth that sets me free. Give me strength to separate myself from anything that does not honor You. In Jesus Name. Amen.
mjg68901 is offline
How do you adjust the ride height? kaeyou77 The ZX-10R 6 03-16-2007 10:23 AM
Idle Speed Adjust BigDally The ZX-10R 4 10-09-2006 06:57 PM
Can someone help with Fathers day PRESENT? Progressive susp? hotstang46 Vendors deals 0 06-09-2006 03:49 PM
Valve Adjust swjohnsey Performance and Tech 6 07-29-2005 07:39 PM
2 different sport rider susp. settings? youlose The ZX-10R 10 07-04-2005 07:00 PM
