Help with Installing a Akrapovic full evo II Exhaust - Kawasaki ZX-10R.net
post #1 of 10 Old 02-03-2010, 08:51 AM Thread Starter
I need some help installing a full akra exhaust. First off, I want to get your opinions on how hard it is to install a full exhaust? Should I attempt it my self? I am somewhat mechanically inclined. Also should I be wary of anything when I am installing the system to prevent the bike from throwing any codes? Thanks. Alos does anyone have any step-by-step instructions. Thanks.
zx10rracer83 is offline
post #2 of 10 Old 02-03-2010, 08:55 AM
zx10Duran's Avatar
I did my full exhaust on my 14 it was challanging but do able so I say go for it!
lotta newbies, where did all the regulars go?
zx10Duran is offline
post #3 of 10 Old 02-03-2010, 09:03 AM Thread Starter
Also is it necessary for me to replace it with new gaskets?
post #4 of 10 Old 02-03-2010, 09:30 AM
WLTD's Avatar
you posted the same thing twice. I replied in the other thread, but again you should be able to do it easily and u should replace the gaskets but if you didn't already buy new ones you might as well reuse them. I have an exhaust leak which will be fixed in a week or so. I only recommend to have a needle nose pliers for the springs...all else should be a peice of cake. You'll enjoy the sound...I do!
Florida has a poor job market! :headshake
WLTD is offline
post #5 of 10 Old 02-03-2010, 09:50 AM
5-F Dawg's Avatar
when you take yours off just be careful to pull the headers out straight and evenly and you should be able to re-use them..i reused mine and no leaks or anything!
BOOM!!! SHAKE AND BAKE
5-F Dawg is offline
post #6 of 10 Old 02-03-2010, 10:08 AM Thread Starter
I am also assuming you have to drain coolant and drop the radiator correct?
post #7 of 10 Old 02-03-2010, 03:07 PM
redline659's Avatar
Its easier to get to everything with the rad out of the way. Spend the 20 or 30 bucks and get new gaskets.
redline659 is offline
post #8 of 10 Old 02-03-2010, 03:43 PM
rkwaki's Avatar
Instead of needle nose try a heavy gauge clothes hanger and make a small 'V' at the end (bend with a vice grip) so that you can get it out of the spring after
rkwaki is offline
post #9 of 10 Old 02-03-2010, 06:23 PM Thread Starter
Why does akra say to reuse the stock gaskets then?
post #10 of 10 Old 02-03-2010, 08:15 PM
dirt ninja's Avatar
Images: 9
I have average size hands and can install the system without removing any radiator brackets... Just do yourself a favorite and get a 12mm i think gear rachet with the bendable head. If this is your first time removing a stock exhaust then you can probably reuse the old gaskets.
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
Help with Installing a Akrapovic full evo II Exhaust zx10rracer83 General Motorcycle Discussions 15 02-12-2010 08:03 PM
'06 Akrapovic EVO Full Exhaust Ti/ Carbon FOR SALE!!! Brendin87 Parts, Gear and Accessories 12 10-25-2009 05:37 PM
Full Akrapovic titanium EVO race exhaust And Ignition Module 208868 Parts, Gear and Accessories 11 06-04-2009 01:52 PM
04-05 Akrapovic Evo Full System 05pearlmagma10r Wanted: Buy or Trade 2 02-07-2008 08:02 AM
04 Akrapovic Evo Full Exhaust for sale nmsu Parts, Gear and Accessories 3 10-28-2007 11:56 AM
