help! gear will not engage - Kawasaki ZX-10R.net
 6Likes
Closed Thread
post #1 of 47 Old 03-23-2015, 10:44 AM Thread Starter
Abo7maid's Avatar
Ok. I'm at the track, bike starts. Put it in first, no fuckin gear. instrument cluster shows that it is in first, let go of the clutch, no gear engaged. Go to second, still no gear engaged... WTF is going on guys??? My bike has 13k miles on it. nothing been touched mechanically. Was out at laguna last weekend and bike went home in perfect condition. HELP!!!
Abo7maid is offline
post #2 of 47 Old 03-23-2015, 11:00 AM
SkyDork's Avatar
Well, that's a new one. Very interesting...
So, the gear indication comes off of the shift drum. If the indication on the dash is working properly, then the shift drum is turning. If it's not going fully into gear, then there's a shift fork problem most likely.
Is there any resistance when moving the shift lever? Into any of the gears? If you have a rear stand available, put it up on the rear stand and try going through all of the gears with the clutch engaged as if you were riding the bike. If you can upshift past 1st gear in this scenario, then the output shaft is rotating and the PNF is disengaging.
#WordCrimes
SkyDork is offline
post #3 of 47 Old 03-23-2015, 11:01 AM Thread Starter
Abo7maid's Avatar
Ok found out... my counter shaft nut walked off the bike.... how the fuck does something like this happen.. Damn it...
Abo7maid is offline
post #4 of 47 Old 03-23-2015, 11:07 AM
JUICEBOX's Avatar
White people problems
JUICEBOX is offline
post #5 of 47 Old 03-23-2015, 11:08 AM
SkyDork's Avatar
Well, that's an easy fix compared to a tranny problem. Still, that shouldn't happen. Did you fold the washer over the nut correctly to lock it into place and prevent that from happening? Did you apply loctite to the threads like from the factory?
When the bike accelerates, the natural tendency is to tighten the nut on the countershaft as it rotates. But under deceleration, the tendency is to loosen the nut. That's why the safety washer is there and needs to be folded completely over one of the flats on the nut to lock it down.
Be thankful this happened in the pits and not out on the track! If you lose your chain out there you'll be lucky to just screw up your motor and not total the bike and get badly hurt!
#WordCrimes
SkyDork is offline
post #6 of 47 Old 03-23-2015, 11:08 AM
Shift_Nashville's Avatar
As in the front sprocket nut???
Shift_Nashville is offline
post #7 of 47 Old 03-23-2015, 11:12 AM Thread Starter
Abo7maid's Avatar
Here is what I'm seeing.. it was torqued to spec when the sprocket was changed.. the thing was folded over.. damn I am just pissed off right now. Way to to ruin a day.
Abo7maid is offline
post #8 of 47 Old 03-23-2015, 11:17 AM
Formerly "bms"
BrandonZX10R's Avatar
Time for a bath and did it mess anything up?
BrandonZX10R is offline
post #9 of 47 Old 03-23-2015, 11:17 AM
JUICEBOX's Avatar
I retract my smart ass comment "figured it didn't do any harm" that sucks man
JUICEBOX is offline
post #10 of 47 Old 03-23-2015, 11:19 AM
SkyDork's Avatar
Yeah, is the sprocket cover removed from the bike all the time? The purpose of that and the more open "race" sprocket covers is to retain that nut should it start to loosen. It will back off until it touches the cover and stop. The tab on the retaining washer would have to fracture and break off for the nut to come off like that.
You're going to have to inspect the splines on the countershaft and the sprocket to be sure they aren't mangled if you intend to reuse the sprocket. They could be all buggered.
Again, just be glad it didn't happen out on the track.
#WordCrimes
SkyDork is offline
Closed Thread
Gsxr will not engage nuetral dgraver Performance and Tech 27 04-08-2012 05:50 PM
Gen 4: ZX10R 2nd Gear 210Km/H,3rd Gear 249Km/H CalvinSars Pictures and Videos 0 09-13-2011 10:33 AM
Gen 4: Zx10R 2011 2nd Gear 210Km/H, 3rd Gear 249Km/H CalvinSars Pictures and Videos 0 09-13-2011 02:15 AM
Weather Gear? Icon Patrol Waterproof Gear 5-F Dawg General Motorcycle Discussions 7 11-20-2010 08:35 PM
