HELP...Gas Cap Won't Open - Kawasaki ZX-10R.net
post #1 of 29 Old 08-04-2007, 08:53 PM Thread Starter
Shawng2020's Avatar
Images: 9
Went riding all day today, filled up twice, had a good time. On the way home stop to fill her up again, and the gas cap won't open. What the hell happened, it feels like the key is going to break off in the cap. HELP. I'm freaking out I had a good time today, and plan on riding out in the morning tomorrow. Someone please help. I'm pushing down and everything. This has had to happen to someone else before. Please Help. How do I open this thing without breaking my damn key. HHHHEEELLLLPPP me please.
Shawng2020 is offline
post #2 of 29 Old 08-04-2007, 08:58 PM
FAF
Rent this space
WD40 , does the trick, I have had the same problem.
FAF is offline
post #3 of 29 Old 08-04-2007, 08:59 PM
FAF
Rent this space
If you dont have any WD handy, a gloop of cooking oil works.
FAF is offline
post #4 of 29 Old 08-04-2007, 08:59 PM
Chickenstrip Eater
SUPER K's Avatar
Send a message via MSN to SUPER K
wd40 and light tapping on the cover,repeat and repeat until it opens.
http://i117.photobucket.com/albums/o45/josh10r/IMG_0144-1-1-1.jpg
Sent from your mom's IPhone using dirty fingers
SUPER K is offline
post #5 of 29 Old 08-04-2007, 09:04 PM Thread Starter
Shawng2020's Avatar
Images: 9
Okay, now all of a sudden I can't find any WD40, so I tried the cooking oil. FAF do I put it on the key or actually in the cap where the key goes?
post #6 of 29 Old 08-04-2007, 09:05 PM Thread Starter
Shawng2020's Avatar
Images: 9
Exactly what do you mean tap?
post #7 of 29 Old 08-04-2007, 09:05 PM
:iamwithst
FLOOD that keyhole with WD-40. Work your key back and forth gently. Eventually it will open. Then you ought to take the cap off the tank and invert it so you can flush it out really well. This has happened to a lot of people.
Since it happened to me, I flush out and lube my lock about once a month to prevent it from happening again.
casey is offline
post #8 of 29 Old 08-04-2007, 09:07 PM Thread Starter
Shawng2020's Avatar
Images: 9
GOT IT.......Damn I love this forum. Thanks Guys FAF, Super K, Casey if you are ever in the Southeast GA area, I owe you a drink.
Thanks Again
post #9 of 29 Old 08-04-2007, 09:10 PM
FAF
Rent this space
Guiness, served at 52 degrees F.
FAF is offline
post #10 of 29 Old 08-04-2007, 09:11 PM
Chickenstrip Eater
SUPER K's Avatar
Leavin the bike open to rain and moisture really does a number on the lock mechanism. Try a little white lithium grease on the latches and lube the key and insert in keyhole x4. After you lube the keyhole and latches, work the key open and shut a few times, remove excess grease and you should be good for a while.
SUPER K is offline
How to open the headlights TOXIC Performance and Tech 9 05-11-2007 03:17 PM
Open Headers! AGENTORANGE636 Performance and Tech 21 09-27-2006 04:31 PM
Open Invitation Middleye The Out House 2 08-17-2005 02:28 AM
Scandinavian open.... Macke Race and Stunt 18 08-05-2005 12:20 AM
Got to open her up a bit today! mach_man_187 The ZX-10R 29 03-31-2005 11:47 AM
