HELP front sprocket issue speedo pickup no holes - Kawasaki ZX-10R.net
post #1 of 10 Old 05-26-2007, 01:03 AM Thread Starter
Mustard's Avatar
installing new chain and sprockets, i pull the new front out of the packaging and its missing the holes! I think this will cause an issue with the speedo pickup? am i correct? I'm pissed because i don't have a car and the only other bike i have to ride is my mates, plus i need to get to work on monday and to the airport tomorrow. Can anyone let me know?
Also somehow either i or the shop screwed up and i got a +1 in the rear (i was going for stock sizes) will it make much of a differance if i go -1 in the front? i may do that if this one doesn't work without the holes.
cheers.
Once i thought more than two strokes was masturbation. Now I realise that 4 feel better, and who am I to argue with my feelings.
05 Black/white road/track zx-10r. Race fairings with stock headlight custom blinkers, Brembo MC, HEL braided lines, Toby dampner, Mustard Block-off plates, plugged airbox, Mustard Heel guards, Mustard Ram-air tube support, custom flip-up rear fender eliminator, custom rear fender, custom seat cowl, corsa 111's.
Mustard is offline
post #2 of 10 Old 05-26-2007, 01:32 AM
MIA Ex-Mod
Tread70's Avatar
Me and Bloo are running -1/+1 at 16/40, I really love it. I don't think the holes will affect anything.
Tread
Tread70 is offline
post #3 of 10 Old 05-26-2007, 01:45 AM
My front sprocket (AFAM) doesn't have any holes. It's fine.
You will probably REALLY like -1/+1.
Only your speedometer will read about 14% high.
If you just run stock in the front and +1 in the back you probably won't notice much of a difference.
casey is offline
post #4 of 10 Old 05-26-2007, 01:51 AM
ZX-10R_04's Avatar
-1 Front way better take off & better out of corners ... Not as taller geared so lose a little top end but who needs that
Bmc filter, Hels Braided Brake lines, Nissin ZX14 Calipers, Brembo, RCS19 M/C, Ohlins damper,Fender Eliminator, Puig screen, Smoke Integrated taillight, Green front indicator lens's, Mirror block plates, Gauge Mod, Vortex rear sets, Personalized # Plate, Pazzo levers, 1/5th Throttle insert, H.I.D Headlights 5000k, Seat cowl, Gen 3 Swingarm, Titanium exhaust hanger , Racefit Growler ,GIpro TRE , Michelin pilot pures, -1 front sprocket, PCIII, SpeedoHealer v4, Factory Pro V Stacks
ZX-10R_04 is offline
post #5 of 10 Old 05-26-2007, 03:42 PM
Dragone's Avatar
Images: 11
hmm, better? Just depends on how you ride and on what your circuit is.
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #6 of 10 Old 05-26-2007, 08:06 PM
PaSt's Avatar
if you look carefully, it doesn't look like it uses the sprocket to measure speed, it looks like it uses the 4 sides of the mounting nut. I thought so this myself when I did my front and the sprocket was flat. but I got everything mounted and the speedo regestered. I also noticed that the sensor looked like it was pointing at the square part of the nut.
PaSt is offline
post #7 of 10 Old 05-27-2007, 04:19 PM
Sensor has nothing to do the holes on the sprocket.
Most (myself included) do agree that the -1f helps the bike out a bit. I wouldn't say its a huge night and day difference but does assist in acceleration at lower rpms better.
06450F is offline
post #8 of 10 Old 05-27-2007, 06:35 PM
06Neenja's Avatar
The holes are for weight reduction.
06Neenja is offline
post #9 of 10 Old 05-28-2007, 09:56 AM
I thought the holes were over processing so they could charge us more.
06450F is offline
post #10 of 10 Old 05-28-2007, 05:45 PM
gearing down rocks..i was at 15 /46 when i got the ten...dont go even near that far....now at 17/46 its pretty decent.
ballsout1 is offline
Front Brake issue hotfocuson18s The ZX-10R 12 05-29-2007 05:52 PM
2003 Z1000 Part# 13144-1320 front sprocket and Speedo Harness Soulja Vendors deals 2 05-23-2007 09:16 AM
Indicated max speed with speedo healer and -1f sprocket? 06450F Performance and Tech 18 05-11-2007 10:42 PM
Speedo Issue Post PCIII - TRE install ctjackster Performance and Tech 6 06-23-2006 11:34 PM
Loose speedo wire or pickup ???? Austin10RPowers The ZX-10R 2 11-04-2004 07:58 PM
