Gen 4: 2011-2015 Help: Front Brake Issues? - Kawasaki ZX-10R.net
 1Likes
post #1 of 11 Old 05-28-2015, 07:10 PM Thread Starter
DJNMS3's Avatar
Exclamation Help: Front Brake Issues?
So, today I was riding my Gen.4 ZX-10R and noticed that whenever I would ride the front brakes a little harder than normal, the bike would start vibrating, rattling, and jolting a bit.
I rode my buddy's Gen.4 ZX-10R and his bike doesn't do that. You also have to squeeze my brake lever a little deeper than usual to really use the brakes. However, when you squeeze his brake lever, it is very sensitive and the brakes engage right away.
Could this be a sign of:
-warped brake rotors?
-bent brake rotors?
-bad brake pads?
-bad brake lines?
-loose steering head bearings?
Any help is greatly appreciated!
Thanks!
DJNMS3 is offline
post #2 of 11 Old 05-28-2015, 10:07 PM
Sounds like a brake rotor problem. Check all the mounting points on the rotor. Sometimes they pull away from the mounts.
Mr. White10 is offline
post #3 of 11 Old 05-29-2015, 09:19 AM
SkyDork's Avatar
Head bearings need tightening a bit.
#WordCrimes
SkyDork is offline
post #4 of 11 Old 05-29-2015, 09:04 PM Thread Starter
DJNMS3's Avatar
Sounds about right. But, why would my brake lever take more effort to pull to engage the brakes than my buddy's brake levers, which are very sensitive and engage right away when you barely pull it?
DJNMS3 is offline
post #5 of 11 Old 05-29-2015, 09:22 PM
The Pace
scout's Avatar
What do the pads look like.
scout is offline
post #6 of 11 Old 05-29-2015, 10:00 PM
White Fang's Avatar
Some o' these posts scare me. This guy has some kinda problem, either the brakes, the master cylinder, air in the lines, pads, rotors...maybe the steering bearings? Dude, I would really say take the bike to a good mechanic because there are too many things that can go wrong and I'm sorry, but the front brakes are the last thing I would want to have fail on me.
I would rather the traction control stop working.
Just sayin'...
White Fang is offline
post #7 of 11 Old 05-29-2015, 10:20 PM
TechX's Avatar
I had a bad master on my 2012. I would bleed the air out and the lever was nice and firm but two days later it would be all squishy. I did that a few times with same results so I went to a Brembo.
TechX is offline
post #8 of 11 Old 05-29-2015, 10:26 PM Thread Starter
DJNMS3's Avatar
Just sayin'...
Yeah, I think I might take it to the guy who did my tires. He knows his stuff.
Not sure to be honest. Haven't checked them out. But, my brakes don't make any noises or squealing.
White Fang likes this.
DJNMS3 is offline
post #9 of 11 Old 05-29-2015, 10:31 PM
White Fang's Avatar
That happens. Suzuki had a big recall on their m/c's for a lot of the Gixxers. Had to get mine replaced.
post #10 of 11 Old 05-29-2015, 10:36 PM
SkyDork's Avatar
Based on the symptoms described with the juddering happening in the front end under heavy braking, that's typically indicative of a loosened head bearing. At lower speeds, it isn't as prevalent but as the speeds increase and the braking forces get higher, the slip in the bearings becomes evident. And the front starts to shimmy and judder.
When was the last time the brake fluid was changed? The firmness in the lever is probably related to some water in the fluid if it hasn't been changed in the last couple of years. Brake fluid is hygroscopic and will absorb water over time. It could also be a bad or failing seal in the master cylinder. But it would be most prudent to change the fluid and bleed the system to see if it affects the problem before moving on to the more complicated of the solutions.
#WordCrimes
SkyDork is offline
front brake issues PUNISHERKING Performance and Tech 7 05-31-2014 08:31 AM
2005 ZX10r front brake issues Kiwi1 The ZX-10R 6 11-01-2010 08:48 PM
07 ZX-10 Front Brake Issues. BIG NICK Performance and Tech 4 06-22-2010 08:21 AM
Front Brake issues on '07 ZX-10R evoracer518 Performance and Tech 7 07-08-2008 08:47 AM
front brake issues lisiecki1 Performance and Tech 14 07-09-2007 12:31 AM
