HELP with DJ QS not working - Kawasaki ZX-10R.net
post #1 of 30 Old 08-20-2014, 06:41 PM Thread Starter
back to car scene
ls1leadfoot's Avatar
the unit is only 4 months old, and unless its a fluke, I have dicked something up.
I adjusted my rearsets up and back to the highest point of adjustment for a upcoming track day. since I moved it, the qs wont engage. its gp style, and that's the correct unit for my shift pattern. (been on since april with no problems)
I NEVER NEVER had a problem until I moved the rearsets back and up. now if I mess with the adjustment, then ride it, it will shift/engage like its supposed to. I let it sit for 5 days, hopped on it 10min ago and it doesn't work again.
1- do I have it adusted wrong
2- kill time is at 60ms, used to be at 45 until this problem started
3- connection problem?
can you guys think of anything else, and do you want a picure.
thanks in advance.
ps--track day is Saturday, I GOTTA sort this out lol
ls1leadfoot is offline
post #2 of 30 Old 08-20-2014, 06:46 PM
bun1t's Avatar
I would pull the connector and check it with a multimeter.
bun1t is offline
post #3 of 30 Old 08-20-2014, 06:49 PM
dricked's Avatar
Check the switch with a meter to see if it's working. If the switch is working properly that's one thing eliminated. Make sure your linkage is 90deg on the shift shaft as well. I don't know much about the stand alone units.
Wow I just can't type fast enough.
dricked is offline
post #4 of 30 Old 08-20-2014, 07:02 PM
x3 for checking the switch function.
Take a multimeter and put it in resistance.
You should be able to go to the screw terminals on the PCV and leave everything connected. Orientation isn't important as you're only measuring the function of the switch.
You should get an open and no reading (infinite resistance) with no pressure on the linkage; when you put pressure to the linkage, it should close giving you a resistance reading of less than 1 ohm.
ZX10RArcher is offline
post #5 of 30 Old 08-20-2014, 07:04 PM Thread Starter
back to car scene
the sensor is reading on the ohm meter
post #6 of 30 Old 08-20-2014, 07:08 PM
Then either its a positioning problem with the shift rod, knuckle, rear sets... or a configuration problem with the DJ software.
Try playing with the positioning of the linkage by loosening/tightening the shift rods to make sure the knuckle and the shift rod/sensor is at a 90* angle.
If that doesn't work, then try double checking your settings within the DJ software.
post #7 of 30 Old 08-20-2014, 07:19 PM Thread Starter
back to car scene
ok
before I posted, ive switched rods twice, moved the knuckle everywhere possible for engagement.
the washers are behind the heim joint because when the shifter is depressed it will hit the side of the qs
so this is the only configuration ive been able to come up with where it will shift without resistance, and not hit the qs sensor
UGH
lmk
and thanks for the fast responses
ID:	281202   Click image for larger version
post #8 of 30 Old 08-20-2014, 07:27 PM
dricked's Avatar
The bike isn't hard to shift like that? Your knuckle should be 90deg off the shift shaft for the smoothest shifting.
I'd double check the software.
dricked is offline
post #9 of 30 Old 08-20-2014, 07:27 PM
Hrm... I know I had a hell of a time initially getting mine configured but once I did it was solid. Also had to play with the kill time. Just odd how it would stop working.
One thing I noticed is your linkage. Shouldn't it be pointed the opposite direction (up) if you're in a GP shift pattern?
Here is how I had my DJ setup before I sold it and switched out for a standalone ignition kill QS.
post #10 of 30 Old 08-20-2014, 07:37 PM
bun1t's Avatar
Two things.
That is a bad angle for your shift knuckle. I would get a shorter rod. I would also try to flip the sensor so it's not hitting the shifter
I'm assuming your sensor is a pull sensor. I wonder if your shifter is putting pressure on your sensor when shifting and not allowing it to activate at the right time.
bun1t is offline
Gen 4: Mirrors both working Tech5 Parts, Gear and Accessories 2 05-16-2014 08:06 PM
My 06 zx10r...Still working on it bengaliprince Pictures and Videos 6 04-25-2012 11:20 PM
anyone working?!? dc5rn The Out House 7 12-01-2008 06:57 AM
Working with Caulk greentourismo Pictures and Videos 4 02-10-2008 06:44 PM
NWS Is your A/C working right? themightymezzo Adult Content - Photos / Videos - N.W.S. 17 10-08-2007 07:54 AM
