Help! Caliper swap question. - Kawasaki ZX-10R.net
post #1 of 22 Old 07-28-2008, 08:00 PM Thread Starter
BrandensDogs's Avatar
Exclamation Help! Caliper swap question.
I am in the middle, literally, of trying to mount a set of 06 Nissin ZX14 calipers on my 07 10. The problem is with the pads in the Nissins won't go on my rotor.
The Tokico's appear to have a larger opening for the rotor than the Nissins. Is this why people use after market pads? Shouldn't the stockers fit? Any help soon is appreciated!
Back in a bit....buddy just came to help figure out with me.....
BrandensDogs is offline
post #2 of 22 Old 07-28-2008, 08:02 PM
Big Daddy's Avatar
Images: 38
yes they should fit.
Have you tried spreading the pads apart, ie pushing the pistons back into the caliper itself???
Big Daddy is offline
post #3 of 22 Old 07-28-2008, 08:07 PM Thread Starter
Thanks BD in the process of trying your idea now.... will get back in a minute....
post #4 of 22 Old 07-28-2008, 08:10 PM Thread Starter
That seems to have done it, you were a huuuuuge help BD. I will report back later, I only have one caliper off and still still have to put on new lines and bleed etc etc. Thanks!
I hereby bequeath BD ten monopoly rep points!!!
post #5 of 22 Old 07-28-2008, 08:16 PM
ZX-10R_Sinner's Avatar
Congrats on the Nissin Calipers. Please don't put the lines on wrong like I did though, for some reason it matters.
You might want to leave them loose/off when rebleeding though, it helps to cycle the piston in & out to get all the air out. Now please, no perverted comments.
At its core, the Ninja ZX-10R is a motorcycle built for the accomplished rider who can fully appreciate its capabilities--whether put to the test at a racetrack, or merely the focus of bench-racing conversation. It is, by all standards, the embodiment of the ultimate superbike.
Member of The Elite - Growler Group
ZX-10R_Sinner is offline
post #6 of 22 Old 07-28-2008, 09:40 PM
Big Daddy's Avatar
Images: 38
fugger sure takes his time lemme tell ya's
post #7 of 22 Old 07-28-2008, 09:44 PM
Dragone's Avatar
Images: 11
hahaha, that was a funny brandensdogs. The "newb experience in brakes" scenario. But yes, you should be fine if you did as mentioned above.
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #8 of 22 Old 07-28-2008, 11:13 PM Thread Starter
Well the brakes are super tight now, I still have to ride it but that will wait to morning when it is light and I check fitting etc. It took one friend and one neighbor but we got it done.
I used the super cheesy eight dollar little fill bottle with the hose and it worked fine, just took a while. Had to do the MC twice and one line twice but otherwise it went really well. Didn't even use a full can of fluid.
The goodridge lines were a bit long but still went in okay. Thanks again BD and everyone!
post #9 of 22 Old 07-28-2008, 11:16 PM Thread Starter
How did you put your lines on wrong? I hope I did mine right. I have a double banjo off the master and a straight line to each caliper from there. The shorter line went first and the longer second (from the MC).
post #10 of 22 Old 07-28-2008, 11:57 PM
kawi1000's Avatar
Images: 26
Nissin Caliper
Becarefull My first test ride almost threw me in front of the bike with 19x18 Brembo MC and Galfer HH pads.
kawi1000 is offline
Anyone done the R1 caliper swap??? Bottlerocket Performance and Tech 10 07-12-2008 01:27 AM
Another caliper question JD81 Performance and Tech 5 12-03-2007 04:14 PM
ZX-14 brake swap question Alien10 Performance and Tech 15 10-28-2007 11:05 PM
Front brake caliper question... Older Guy Performance and Tech 7 09-07-2007 09:12 PM
Rear caliper freeplay question DangfastZX-10 The ZX-10R 4 04-24-2006 09:29 PM
