Help! Caliper Bolts...F**ked things up good this time - Kawasaki ZX-10R.net
post #1 of 25 Old 03-26-2010, 12:13 PM Thread Starter
lunitk's Avatar
Uggggggggggggggggggh!!!!! So I just stripped out both the bolts on one of my calipers trying to get them off and have no idea what to do. I'm not sure if I was hulked up when I put them on last or I had the wrong setting on the torque wrench but they would not break free. Not having the most patience in the world, I tried to force one of them out and fucking rounded off the inside of the bolt and the stupid star shaped allen socket attachment. And when I say rounded....I mean like circular; no flat edges for anything to be able to get a grip on. So instead of just walking away and regaining my composure, I tried to remove the second bolt.....not a smart move because the result was the same. They were questionable last time and I should have replaced them.....lesson learned.
Tried drilling one of the bolts to use an easy out and the easy out just snapped off inside of the bolt so thats fucking sweet. The bolts are so tight in the forks I cant see how I can get enough leverage on the easy out to break them free.
Not really sure what to do here....any help would be greatly appreciated.
lunitk is offline
post #2 of 25 Old 03-26-2010, 12:17 PM
Speed Freak
garth285's Avatar
if you have any Torx bits you can try hammering a torx bit slightly larger into it and backing it out... i wonder if you can heat it up anyway with out damaging anything....
garth285 is offline
post #3 of 25 Old 03-26-2010, 12:20 PM
Quick10's Avatar
Hmm I think a trip to the machine shop might be in your future.
Quick10 is offline
post #4 of 25 Old 03-26-2010, 12:22 PM Thread Starter
lunitk's Avatar
Tried with the bigger torx bit but no luck....this is starting to piss me off. I'm thinking of dremeling flat edges on the head of the bolt and trying that with a wrench but I dont think there is enough "meat" on the head of the bolt to grab onto.
Is there like a super penetrating liquid that might help things out a little bit? I know liquid wrench but wondering if there might be anything stronger to help out from the inside of the threads. Gahhhh!
lunitk is offline
post #5 of 25 Old 03-26-2010, 12:29 PM
The best way to remove it now would be with a hammer,and a sharp chisel. You need to hit it in the direction needed to loosen it. Mike.
880turbo is offline
post #6 of 25 Old 03-26-2010, 12:35 PM
vice grips
TN10R is offline
post #7 of 25 Old 03-26-2010, 12:42 PM
TENN10's Avatar
Images: 145
Absolutely! I would take it to a machine shop before you do any more damage.
Sh*t happens. Don't make it worse using the wrong tools. My
TENN10 is offline
post #8 of 25 Old 03-26-2010, 12:43 PM
ninja9r's Avatar
Originally Posted by tenn10 View Post
sh*t happens. Don't make it worse using the wrong tools. My
ninja9r is offline
post #9 of 25 Old 03-26-2010, 01:03 PM
photodigm1's Avatar
Craftsman makes a bolt/nut extractor kit....thats what I used on my caliper bolt...it looks like a nut with these spiral cut teeth...just hammer it on and use a wrench to get it out.....
Garth I tried the torx also....but no worky....heres what it looks like
photodigm1 is offline
post #10 of 25 Old 03-26-2010, 01:14 PM
hammer and sharp punch
dplater71 is offline
Caliper bolts Crazy-zx10r Performance and Tech 11 07-23-2010 07:00 PM
Caliper Bolts Dick Head Dave Wanted: Buy or Trade 4 10-10-2009 01:16 PM
caliper bolts rainking12 Wanted: Buy or Trade 8 06-18-2009 11:41 PM
caliper bolts spacing 07 sch2046 Performance and Tech 6 01-23-2008 05:59 PM
Front Caliper Bolts. martek Performance and Tech 4 07-04-2006 11:38 AM
