Help: Bike won't start while in gear - Kawasaki ZX-10R.net
post #1 of 20 Old 02-20-2005, 03:39 PM Thread Starter
10inja's Avatar
All the sudden the bike won't start while in gear (ofcourse the kickstand is up and the clutch is pulled in). It used to start.. it just won't any more.. I have to put it in neutral
Anyone else having this problem?
It's not the kickstand sensor... because when the kick stand is down and I try to start the bike.. the right bottom red light flashes.. If it's up, that light doesn't flash.. I'm thinking it's a sensor on the clutch??.. hmm...
10inja is offline
post #2 of 20 Old 02-20-2005, 03:57 PM
OG Post Whore
stunnerific_harry's Avatar
Send a message via AIM to stunnerific_harry
im not sure but mine does start up while in gear
Kip: Napoleon, don't be jealous that I've been chatting online with babes all day. Besides, we both know that I'm training to be a cage fighter.
Pedro: Yes. I don't understand... they say you're not allowed to have pinatas that look like real people, but in Mexico, we do it all the time.
Pedro: Vote for me, and all your wildest dreams will come true.
stunnerific_harry is offline
post #3 of 20 Old 02-20-2005, 06:44 PM
zrxhooligan's Avatar
Send a message via AIM to zrxhooligan Send a message via Yahoo to zrxhooligan
check the connection at the clutch lever. sometime they get wet from washing and need drying.
zrxhooligan is offline
post #4 of 20 Old 02-20-2005, 08:17 PM
SP8
SP8's Avatar
Do you have a PC3USB installed? If yes, that's why. It also take longer to start. The starter has to turn the crank longer with the PC3.
SP8 is offline
post #5 of 20 Old 02-20-2005, 08:52 PM
Check the switch on the clutch. I had to fix mine also.
jeffzx998 is offline
post #6 of 20 Old 02-20-2005, 08:54 PM Thread Starter
10inja's Avatar
how's the PC3USB a problem. I've always had it and was always able to start while in gear. It's just recently that it quit working.
I gotta check out the connection like holeegan said. But, if it did get wet.. then wouldn't get dry after 2 weeks of not washing it.. hmmm.. but I'll check it out anyways
10inja is offline
post #7 of 20 Old 02-20-2005, 09:49 PM Thread Starter
10inja's Avatar
I think it is the switch... I checked the connection: looks good.
How did you fix it? did you replace it with a new one? is it covered under warranty?
I'm tempted to take it appart and play with it...
10inja is offline
post #8 of 20 Old 02-20-2005, 09:58 PM
Originally Posted by SP8
Do you have a PC3USB installed? It also take longer to start. The starter has to turn the crank longer with the PC3.
I noticed that about mine. An extra second of cranking. Now I feel better.
Mike
BIKEMIKE is offline
post #9 of 20 Old 02-21-2005, 12:11 AM
Send a message via AIM to gladding24
to see if it's the switch, unplug it (open circuit) and see if it starts with the kickstand down. If it doesn't then short the switch leads together with a piece of wire(closed circuit) and it should start. If still not, the switch is not the culprit. or, check the wiring diagram in the service manual, that should tell you if the switch is normally open or closed.
Stop Whining!!!
It ain't easy being Green ~ Kermit The Frog
Arguing on the internet is like running in the Special Olympics.....Even if you win...you are still retarded
CaliSuperbikes- "these are high strung machines, and we're giving them a constant dose of Red Bull"
gladding24 is offline
post #10 of 20 Old 02-21-2005, 07:56 AM
[I'm tempted to take it appart and play with it...[/QUOTE]
I don't remember what i did.It happened shortley after i got the bike. Take the switch apart. I do remember it was something simple.
Got my new bike yesterday. ZX10 Guy The ZX-10R 19 10-13-2004 10:20 PM
Love my new ZX-10R - 150 mile impression (with pics!) JLove The ZX-10R 26 10-12-2004 01:18 PM
RedElk's ZX10R Ride and Adventure review swft The ZX-10R 11 03-11-2004 01:24 PM
Some driving test`s with the ZX-10R Mike_P Netherlands Archives 16 01-07-2004 12:10 PM
