Gen 1: 2004-2005 Help!!!! Any ideas??? - Kawasaki ZX-10R.net
post #1 of 13 Old 07-14-2012, 03:16 PM Thread Starter
Heavyweight's Avatar
I just put a new rear tire on my 04 zx10 and seems like it lost power. I had a 190/60 went to a 190/50. But the bike is harder to wheelie now and just doesnt see, t have as much power as it did a few weeks ago. any ideas?
Livin The Dream
Heavyweight is offline
post #2 of 13 Old 07-14-2012, 03:22 PM
ZXRANDY's Avatar
Changing tire profiles is like changing the gearing. I belive going that much smaller in the profile would be like going -2 or -3 on the rear sprocket. That would be a BIG change.
ZXRANDY is offline
post #3 of 13 Old 07-14-2012, 03:43 PM Thread Starter
i thought it changes the gearing up so id have more bottom end, but if you are correct that would explain it. are you certain the gearing drops??
Livin The Dream
post #4 of 13 Old 07-14-2012, 03:50 PM
ZXRANDY's Avatar
Sorry but you are right and im wrong, the gearing change should of gave you more bottom end.......I checked it on gearingcommander.com.....maybe your chain is too tight/loose?
ZXRANDY is offline
post #5 of 13 Old 07-14-2012, 07:56 PM Thread Starter
The chain could be the culprit maybe, would a slightly overtight chain make the performance that poor?
Livin The Dream
post #6 of 13 Old 07-14-2012, 07:58 PM Thread Starter
Could a slightly overtight chain have that much effect on it?
Livin The Dream
post #7 of 13 Old 07-14-2012, 08:00 PM
ZXRANDY's Avatar
A little, how dramatic is the change.
ZXRANDY is offline
post #8 of 13 Old 07-14-2012, 08:01 PM Thread Starter
And when the tire comes off the ground it does tend to drift to the chain side
Livin The Dream
post #9 of 13 Old 07-14-2012, 08:18 PM Thread Starter
I thought it was fine maybe an inch of slack
Livin The Dream
post #10 of 13 Old 07-14-2012, 08:56 PM
zx racer's Avatar
if you have a inch of slack then the chain isnt your problem and 190-50 is the stock tire size so that shouldnt be a porblem either... might be your clutch is going out or may need to adjust the cable.
05 ZX-10R SWB.
zx racer is offline
Mod Ideas cswerner The ZX-10R 9 01-06-2012 09:34 PM
Need Help with Ideas!!!! hraponte The ZX-10R 1 10-11-2010 03:32 PM
Need help with Ideas!!!! hraponte The ZX-10R 0 06-21-2010 07:20 AM
Need Ideas Blink180Wilhelm Pictures and Videos 38 12-28-2009 05:50 PM
new some ideas! zx10r85 The Out House 20 01-22-2008 09:19 AM
