Help!!!!!!!! - Kawasaki ZX-10R.net
post #1 of 10 Old 04-29-2006, 07:29 PM Thread Starter
Help!!!!!!!!
If anyone can help you would greatly reduce my stress%$#!
I have gotten a set of wheels of ebay that are supposed to be zx-10r wheels, got them out of the box and they look great! One problem, the wheel bearings are a larger diameter than the stock wheel bearings, by about 4-5 mm circumfrence. Has anyone ever seen this OR can anyone tell me if the ZX-RR wheels use larger wheel bearings? The markings on the front wheel are exactlly the same as my other zx-10r wheel just with larger bearings?
rocket10r is offline
post #2 of 10 Old 04-29-2006, 07:34 PM
jblaze's Avatar
Images: 14
i believe you got a set of zx6r or zx6rr (05/06) wheels, that sounds about the same difference in diameter from the 10r
jblaze is offline
post #3 of 10 Old 04-29-2006, 07:35 PM
jblaze's Avatar
Images: 14
btw, where in NC are you from? charlotte? got a few zx10r owners from charlotte here
jblaze is offline
post #4 of 10 Old 04-29-2006, 07:44 PM Thread Starter
Are you saying the wheel bearings for a zx-6r are larger than zx-10r?
post #5 of 10 Old 04-29-2006, 07:46 PM
jblaze's Avatar
Images: 14
yes the zx6r, the front wheel is like the 0610r (which is larger than the 04/05 zx10r), you are putting this on a ............ 04/05 10r, correct?
jblaze is offline
post #6 of 10 Old 04-29-2006, 07:50 PM Thread Starter
Yes I have a 2005 zx-10r, the front wheel bearings are smaller than the bearings that are in the wheels I bought?
post #7 of 10 Old 04-29-2006, 07:50 PM
jblaze's Avatar
Images: 14
so hopefully you got a set of 06 zx10r rims, cause then you can at least use the rear ones, if they are zx6r rims, you wont be able to use it at all
jblaze is offline
post #8 of 10 Old 04-29-2006, 08:02 PM Thread Starter
I guess my biggest question would be are the zx-6r front wheel bearings larger than the zx-10r??
post #9 of 10 Old 04-29-2006, 08:19 PM
jblaze's Avatar
Images: 14
yes, the front is
jblaze is offline
post #10 of 10 Old 04-29-2006, 08:30 PM
is there a part # on your wheels ?
oneradten is offline
