Heavy CLICK/THUD when braking, 06 10r... - Kawasaki ZX-10R.net
post #1 of 14 Old 08-18-2007, 03:36 AM Thread Starter
Send a message via AIM to willybeen
Only when i brake hard, it feels like the whole front end is loose (upper fairing, headlights) I dont believe my ram air tube is broke (my 636 broke and had to be replaced) but I feel like something is very NOT connected to the bike. Anybody else have this problem?
thanks
willybeen is offline
post #2 of 14 Old 08-18-2007, 08:39 AM
themightymezzo's Avatar
I think I've had that happen on my 05. Not sure what it is either though?!?!
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
post #3 of 14 Old 08-18-2007, 08:47 AM
SalKhan's Avatar
Send a message via AIM to SalKhan Send a message via Yahoo to SalKhan
Double check Brake Carrier bolts? Fork tube clamp bolts all the way around?
Sal Khan
http://www.thelunchjournals.com - Updated 3/8/08!
SalKhan is offline
post #4 of 14 Old 08-18-2007, 09:38 AM
Chickenstrip Eater
SUPER K's Avatar
Send a message via MSN to SUPER K
Search, steering head nut. The large nut under the top triple tree.
http://i117.photobucket.com/albums/o45/josh10r/IMG_0144-1-1-1.jpg
Sent from your mom's IPhone using dirty fingers
SUPER K is offline
post #5 of 14 Old 08-18-2007, 11:11 AM
Big Daddy's Avatar
Images: 38
Originally Posted by SUPER K View Post
Search, steering head nut. The large nut underneath the top triple tree.
Yes research adjusting the head bearings and i suspect you'll find the culprit.
Big Daddy is offline
post #6 of 14 Old 08-18-2007, 11:28 PM Thread Starter
THANKS
sounds like ill have to do some research.. it actually sounds like the upper is moving around and it does tend to flex alot when going over bigger bumps... I hate the design that kawi uses for the ram air tube, but that is my only complaint thus far in the 4 kawi's that i have owned. Thanks again
Next question, anybody here have LSL clip ons? is there a way to adjust them so they dont hit the upper, no matter what i do they seem to rub a bit..
post #7 of 14 Old 09-01-2007, 11:57 PM Thread Starter
bump... ^^^^^^
post #8 of 14 Old 09-04-2007, 10:26 PM
Send a message via Yahoo to THE-ZX10R GUY
its happend to my bike and its the head bolt,located under the dampner,thats if u have an 06 zx10..i think its supposed to have 75foot pounds of torque..not sure though..not a big deal...BY THE WAY STOP DOING WHEELIES AND IT WONT HAPPEN AGTAIN...LOL
THE-ZX10R GUY is offline
post #9 of 14 Old 09-05-2007, 09:45 AM
Mine does something similar on my 05 and I just installed an Ohlins Damper and torqued it correctly.
I'm thinking it's under the triple clamp?
post #10 of 14 Old 06-14-2008, 02:24 AM Thread Starter
Hopefully this will finally be addressed Tuesday when i take it in for some warranty work.
THEN.. ill finally run mid ohio on the 10r. yay.
"pop" under heavy braking from front end loueber The ZX-10R 39 07-14-2007 12:15 PM
new sharp thud noise from tranny? inginekilla Performance and Tech 7 11-08-2006 09:04 PM
something wrong at 3500 rpm (click) TITOUNE11299 Performance and Tech 3 05-31-2006 11:21 AM
What is that CLICK from the pipe?? ZXMustang The ZX-10R 15 06-22-2005 02:25 AM
