Heat Soaked Or Clutch Issues? - Kawasaki ZX-10R.net
post #1 of 8 Old 09-09-2008, 08:23 PM Thread Starter
Hey guys. I am trying to figure out why every time I hit up the strip my best et is one of the first three runs I make. Is this my motor getting heat soaked or is this my clutch doing something funky?
Also my 60' times are the only thing that changes throughout the runs. MPH stays close to the same. So I am guessing this is a clutch issue.
Any help would be appreciated.
Spillman is offline
post #2 of 8 Old 09-09-2008, 11:40 PM
redline659's Avatar
When mine was NA it would run better the hotter it got, because the oil is thinning out and its making more HP. Just like on a dyno the second pull right after the first will usually net a bigger #. If your 60's are getting slower it might be time to look for a new pack and in that case give dwayne a call at cycle concepts he has a drag pack that is supposed to work like butter. However if your 60's are staying consistent then it might just be the rider. Your first rip down the track you might have more adrenaline pumping and you might be riding the bike harder. Try to get consistent and the only way that will happen is with ALOT of seat time. Everyone will tell you in drag racing its all seat time!!
redline659 is offline
post #3 of 8 Old 09-10-2008, 06:56 AM
2006zx10r's Avatar
The ZX-10R does not really have a heavy duty clutch that works all that well at the drag strip. It heats up very fast adn takes a bit to cool down. The ZX-14 has a very similar clutch to the old ZX-11 which we all know was a great bike for the strip.
When I take my 10 to drag I only make about 1 pass every 30-45 min or the clutch starts to slip. It was like this when it only had 1000 miles on it and it is the same even after the clutch plates have been changed once.
I think that what you are experiencing is just a bike that was built to race on a road course not so much on a drag strip. The slipping the clutch at the starting line creates alot of heat. But like I said if you are willing to wait 30-45 min between runs you should be fine.
Even though you will see others doing it. DO NOT!!! put ice on your covers to cool the bike down. This is a great way to cause stress fractures in already thin factory cases.
2006zx10r is offline
post #4 of 8 Old 09-10-2008, 07:42 AM Thread Starter
Guess I will be giving cycle concepts a call then. The clutch has over 50 passes on it.
Spillman is offline
post #5 of 8 Old 09-10-2008, 07:55 AM
redline659's Avatar
One thing I do is open the oil fill port and direct a fan down towards there. This will help evacuate the heat a little quicker. Just made sure no junk goes down there
post #6 of 8 Old 09-10-2008, 08:04 AM
redline659's Avatar
I dunno, I had hundreds on passes on mine and I never had an issue, but mine is a second gen.
post #7 of 8 Old 09-10-2008, 08:17 AM
cueman's Avatar
Try the clutch pack from cycle concepts and heavy clutch spring just use 4 heavy ans 2 oem springs
04 ZX10 muzzy turbo,ported and polished head,carpenter valve springs and valves,kaw race cam,walbro fuel pump,begi fmu,mps airshifter,pcIII and ignition module,strectched 10 over,galfer brake lines,530 ek drag chain,16 front sprocket 45 rear sprocket,gpr dampner,modded clutch basket
cueman is offline
post #8 of 8 Old 09-10-2008, 08:33 AM Thread Starter
Mine is also a second gen. My 60' times drop and level off at 1.66-68. My best 60' is 1.63 and that normally occurs when I first arrive at the track.
What does cycle concepts offer? I took a look at their website but didnt see anything.
Spillman is offline
'06 Clutch issues Gang Green Performance and Tech 1 08-17-2008 10:05 PM
clutch issues! please look, i searched slowblack00 Performance and Tech 39 03-12-2008 04:48 AM
Clutch issues Killentime Performance and Tech 5 05-19-2007 02:20 PM
Clutch issues GARSZX10R Performance and Tech 55 09-13-2006 11:56 PM
Clutch issues dr_wookiee Performance and Tech 5 06-29-2005 10:18 PM
