healtech x-tre install problems - Kawasaki ZX-10R.net
post #1 of 4 Old 01-17-2010, 07:23 PM Thread Starter
ignite15's Avatar
just finished doing the install and started up the bike. it will only start in neutrual and when i try to put it into gear it kills it and throws the an FI plus it only shows 6th gear when the xtre is supposed to allow the factory gear indcator work...what have i done wrong....i check all my conections with a volt meter everything checked out on the xtre side on the factory side only one conector showed anything could this be my problem and what could have caused it.
ignite15 is offline
post #2 of 4 Old 01-17-2010, 07:46 PM
Check your wires. I had mine connected wrong when I first installed it and it threw off the the blinking FI light. Check the negatives match the negatives and positive to positive. That is probably the issue. After I corrected it everything was beautiful, and smiles ever since. Good luck!
There's no such thing as horsepower overload or a bike that carries its front wheel too often.
j1000 is offline
post #3 of 4 Old 01-17-2010, 08:47 PM Thread Starter
ignite15's Avatar
thanks ill give those a try tomorrow also when i took the xtre box out and used the jumper plug and connected the factory plugs back together it would show first gear but would still throw the FI light and kill it.
ignite15 is offline
post #4 of 4 Old 06-15-2013, 06:52 AM
jakeszx10's Avatar
Use solder
I had to solder mine ,those butt connectors are crap,now it works!
jakeszx10 is offline
Healtech X-TRE for 08-09 ZX10 throttledemon The ZX-10R 69 01-30-2012 12:32 AM
'08 Healtech X-Tre for sale Candy08 Parts, Gear and Accessories 14 11-12-2009 03:11 PM
HealTech X-TRE Timing Retard Eliminator Mahlerpg The ZX-10R 4 06-12-2009 07:18 PM
Healtech Electronics X-TRE (Increases HP and removes speed limiter!) Calsportbike-Kim Vendors deals 7 09-05-2008 09:44 AM
Problems with nitrous install??? on1whl Performance and Tech 1 04-03-2005 11:40 AM
