Healtech TRE - Kawasaki ZX-10R.net
post #1 of 3 Old 10-17-2010, 06:55 PM Thread Starter
Luiz_Direito's Avatar
Healtech TRE
Please, I already installed my XTRE but have some doubts, if you could help me I would be very glad and thank you:
1) In the Installation Manual they said there are 3 maps: [ ], [5] e [6] (Neutral, Soft and Normal). Could you, please, tell me the difference between each one in pratice?
2) How to setup the motorcycle to each map?
Thanks.
Luiz_Direito is offline
post #2 of 3 Old 10-20-2010, 02:35 PM
GPfan's Avatar
Im not sold on the difference!! Sorry it may be just me.
As for setting each map. The manual says (im trying to remeber im at work).
Shift the bike to the desired map/gear N,5 or 6. This should be done with the bike not running. Then turn on the ignition key and turn the key off within 5 seconds(ithink).
To varify the setting, turn on the ignition and the gear display will show the desired setting (Blank is neutral) as a confirmation.
So bike off, shift to desired gear/map, key on, key off, switch to neutral then turn on ignition and watch for confirmation on gear display Blank,5 or 6, then the bike should switch to 'N'
Hope this helps
GPfan is offline
post #3 of 3 Old 10-20-2010, 04:48 PM Thread Starter
Thank you very much, I think I realized my mistake!
Healtech X-TRE for 08-09 ZX10 throttledemon The ZX-10R 69 01-30-2012 01:32 AM
Healtech X-TRE for 08 zx10 spikespiegel Parts, Gear and Accessories 7 04-12-2010 11:20 PM
Healtech GI-PRO DS series garth285 Performance and Tech 4 11-30-2009 01:24 PM
'08 Healtech X-Tre for sale Candy08 Parts, Gear and Accessories 14 11-12-2009 04:11 PM
Norbert/healtech are some bad mo'fo's!!! 925stunna Performance and Tech 9 12-21-2008 12:30 PM
