Headlights not turning on, Help! - Kawasaki ZX-10R.net
post #1 of 7 Old 11-30-2009, 07:42 PM Thread Starter
Stealth Rider's Avatar
I just bought DDM Hid's (high and low beam on an 05 zx10), I ran the bike for about 4 days no problems. Today I leave work and the headlights dont turn on! Luckily it was during the day, but I checked all the wires, everything seems fine. Fuses look ok too. I even put back in the stock bulbs to see if those would turn on, but of course not. Any advise? They are 35w (both) 5000k hid's if you were wondering
"The world is made of two types of people: riders and everyone else. In a country full of lawsuits, threat levels, child proof caps, rules and regulations, owning a motorcycle is one of the last ways to give the middle finger to society's expectation that we constantly be caged and protected. We all want our machines to be a representation of ourselves. Those that ride know being on a motorcycle is not just about getting from point A to B."
John Zamora - Super Streetbike
Stealth Rider is offline
post #2 of 7 Old 11-30-2009, 08:30 PM
the fuses "LOOK" ok?
mityaz is offline
post #3 of 7 Old 11-30-2009, 08:31 PM Thread Starter
Yeah, nothings wrong with them
post #4 of 7 Old 11-30-2009, 08:34 PM
did you pull the one that says headlight and confirmed that the filament is intact?
mityaz is offline
post #5 of 7 Old 11-30-2009, 08:45 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
I almost gaurantee its a fuze, you need to replace the 10amp with a 15amp, the reason; the DDM kit pulls 12.4amps at start up then drops below 10amps once the lights are up and running, I had to figure that out after blowing a couple of fuzes then doing some research on how much amperage the ballasts draw. It could be also the DDM kits are notorious for being wriwired wrong on the harness, where it plugs up to the stoch harness, its as simple as switching the wires around in the plug if you want them to fasten properly, or you can just plug them in backwards and the retainer tabs on the plug will be opiisite of the clip, but still will stay put, I switched the wires around inside the plug.
9R to 10R is offline
post #6 of 7 Old 11-30-2009, 09:09 PM
MIdlife PIMP
bodymanruss518's Avatar
Images: 12
Send a message via Yahoo to bodymanruss518
Originally Posted by 9r to 10r View Post
i almost gaurantee its a fuze, you need to replace the 10amp with a 15amp, the reason; the ddm kit pulls 12.4amps at start up then drops below 10amps once the lights are up and running, i had to figure that out after blowing a couple of fuzes then doing some research on how much amperage the ballasts draw. It could be also the ddm kits are notorious for being wriwired wrong on the harness, where it plugs up to the stoch harness, its as simple as switching the wires around in the plug if you want them to fasten properly, or you can just plug them in backwards and the retainer tabs on the plug will be opiisite of the clip, but still will stay put, i switched the wires around inside the plug.
Better to have a gun and not need one, than to need a gun and not have one!!.......
you can lose money chasing women, but,......
you'll never lose women chasing money!!....
bodymanruss518 is offline
post #7 of 7 Old 11-30-2009, 09:17 PM Thread Starter
Yup, it was a fuse. Thougt is was ok but took a closer look this time. I put a 15 in replacement of the 10. Thanks a bunch 9R!!
04 zx10r turning problem Adr3naline fix The ZX-10R 12 07-03-2009 11:25 AM
cause for heavy turning slav Performance and Tech 5 07-16-2007 10:10 AM
turning gabe Performance and Tech 24 03-03-2005 09:46 PM
Turning back the Power Vonstallin The ZX-10R 23 02-07-2005 09:23 PM
zx-10 is turning heads everywhere..... liljunglist2 The ZX-10R 13 06-16-2004 11:26 AM
