Header Wrap? - Kawasaki ZX-10R.net
post #1 of 18 Old 01-17-2010, 03:21 PM Thread Starter
sullysZX10r's Avatar
Header Wrap?
I am considering wrapping my headers w/ teflon. Anyone notice a considerable increase in hp/torque/sound?
RIP 2008 ZX-10R
05' ZX6rr 636
12' ZX-10r
Austin Racing GP2 Slip On, Ivan's Mod, Secondaries Removed, Servo Eliminator, PC5 w/ Custom Map, Hotbodies Smoke Undertail w/ Custom LED, Brembo Master Cylinder RCS 19, Speglier Steel Braided Lines,
sullysZX10r is offline
post #2 of 18 Old 01-17-2010, 04:03 PM
FTHOODZX10R's Avatar
interested
2006 Ebony ZX14
Looking for new 10
Still.....Looking for:
Carbon, Aluminum, or Magnesium wheels, rear sets, velocity stacks,
FTHOODZX10R is offline
post #3 of 18 Old 01-17-2010, 04:34 PM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
Been asked and answered many times.
Lucky10R is offline
post #4 of 18 Old 01-24-2010, 09:13 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
12.5 hp and 13 ft lbs of torque when you wrap yer headers...\\\\\\\\\\\\\\\\\\\\\dont forget it adds fuel milage bt 3 mpg and helps you corner cause it lowers the center of gravity...Seeing you add weight to the front end it helps stunters to do endos as well..
craig_sez is offline
post #5 of 18 Old 01-24-2010, 09:25 PM
YRR
Scavenger8620's Avatar
Scavenger8620 is offline
post #6 of 18 Old 01-25-2010, 08:46 AM
redline659's Avatar
Wow and you guys wonder why people bounce. :headshake
Quit being dick bags
redline659 is offline
post #7 of 18 Old 01-25-2010, 08:56 AM
rkwaki's Avatar
I think my post regarding Garth sums it up.
if you can't say something nice/postive shute the [email protected] up
Now in answering your question a couple of things:
Any horsepower/torque gains - probably not though it will keep you engine temp lower due to the fact that there will not be any radiating heat from the headers/exhaust.
Noise level - the same
Performance gains would be minimal at best but there is an increase in comfort as the under fairing temps go down.
Problem is if it gets wet (caught in rain) there is a chance that you could corrode you exhaust (dependant on materials)
FYI - try using the search function to keep yourself out of trouble.
rkwaki is offline
post #8 of 18 Old 01-25-2010, 09:19 AM
Speed Freak
garth285's Avatar
it will keep some temps down but theres only so many places heat can escape from. I dont like header wrap just because it gets pretty dirty down by the pipe area and it will look great all until you ride in the rain and pick up a buncha of things like oils and rubbers from the road.. If anything I'd do a JET-HOT type ceramic coating to them.
garth285 is offline
post #9 of 18 Old 01-25-2010, 09:44 AM
redline659's Avatar
Like I sent in my PM wrapping the stock exhaust is going to cut its life down quite a bit. The ti they use will become very very brittle and fall apart
post #10 of 18 Old 01-25-2010, 03:42 PM
Supercharged Mod
I wouldn't do it. I'd suggest using a coating of some sort instead.
GoFaster is offline
Header Wrap info Crazi The ZX-10R 10 05-19-2009 10:06 PM
Header wrap? Any gains? NYC_ZX10 The ZX-10R 22 05-16-2008 08:36 PM
header wrap steved57 The ZX-10R 8 04-03-2007 09:35 AM
Exhaust Wrap Jax 10 The ZX-10R 19 03-30-2006 10:40 AM
Stock header vs. Aftermarket header for the zx-10r ZiG 9th Performance and Tech 42 08-18-2005 04:06 PM
