Header is burning the fairing - Kawasaki ZX-10R.net
post #1 of 8 Old 01-15-2008, 09:38 AM Thread Starter
aneconsulting's Avatar
I tried using header wrap, but the header is still burning through the fairing.
Does anyone know of any technics/materials that I can use to prevent the fairing from burning?
Thanks.
aneconsulting is offline
post #2 of 8 Old 01-15-2008, 10:26 AM
edouble's Avatar
Your solution might be to get your bike tuned with a PCIII. Remember header wrap will make the pipes hotter not cooler. If you have a tuned PCIII and are still experiencing issues with heat try adding an insulated heat barrier on you plastics. It is sold at most auto parts stores, OPP racing also sells kits http://www.oppracing.com/products.ph...roduct&id=3033
edouble is offline
post #3 of 8 Old 01-15-2008, 11:11 AM
GEN II Driver
ripper's Avatar
need more info. t/m/y bike and any mods. taking a stab in the dark from the comfort of my armchair: if you've added pipe/air filter without a tune/correct map you're bike will run lean/hot. not good for your fairing and not good for your motor. luck...
ripper is offline
post #4 of 8 Old 01-15-2008, 11:26 AM
Big Daddy's Avatar
Images: 38
A description or pic of the effected area would help us help you.
Big Daddy is offline
post #5 of 8 Old 01-15-2008, 03:49 PM Thread Starter
I can't post any pictures as the fairing is now in a body shop getting painted.
However, thanks for all the help.
post #6 of 8 Old 01-15-2008, 04:03 PM
pr0phet00 is offline
post #7 of 8 Old 01-15-2008, 04:20 PM
Had the same problem with a Honda 1000RR once, sent it to get ceramic coated. That stopped the fairing from melting. Hope that helps
howitzer is offline
post #8 of 8 Old 01-15-2008, 05:17 PM
Green Hippie
treyzx10r's Avatar
A/C aluminum tape will sometimes help
treyzx10r is offline
Burning oil??? TX06'10r Performance and Tech 24 07-27-2007 06:17 PM
Burning oil warranty work anyone else? Mustard The ZX-10R 9 05-02-2006 07:28 PM
Stock header vs. Aftermarket header for the zx-10r ZiG 9th Performance and Tech 42 08-18-2005 05:06 PM
burning smell??? TTLex The ZX-10R 19 07-15-2005 03:19 PM
Burning oil. LOTS. Help N1NJAZX6R Performance and Tech 18 06-11-2005 11:02 AM
