Head Removal Question - Kawasaki ZX-10R.net
post #1 of 9 Old 12-11-2009, 10:32 PM Thread Starter
Guys,
I'm in the process of pulling the head from my bike and have gotten as far as removing the cams but have a question regarding removal of the front cam chain guide. According to the service manual you first need to remove the idle gear and crankshaft sensor. Ok, I have no problems with that. However, you also need to remove the starter clutch and according to page 16-51 in the manual, you need to hold the alternator rotor steady with a rotor holder while you unscrew the starter clutch bolt.
My question is what tool are people using to hold the rotor steady? I'm sure most aren't using the $200+ thingy they're pushing in the service manual.
Thanks!
Damon
vdharris is offline
post #2 of 9 Old 12-11-2009, 11:11 PM
Originally Posted by vdharris View Post
Guys,
Thanks!
Damon
impact gun ..... no really thats what we use
J-N-M Motorsports home of the fastest ZX-10's
Da Flea is offline
post #3 of 9 Old 12-12-2009, 02:49 PM Thread Starter
Thanks man, I took the generator cover and stator off and figured out a way to get it done. Hopefully it will be smooth sailing from here.
Thanks again!
vdharris is offline
post #4 of 9 Old 12-13-2009, 01:45 AM
Thanks again!
Da Flea is offline
post #5 of 9 Old 12-13-2009, 10:09 AM
Speed Freak
garth285's Avatar
:iamwithst
garth285 is offline
post #6 of 9 Old 08-21-2010, 07:28 PM
greenman43's Avatar
Images: 33
Originally Posted by garth285 View Post
:iamwithst
So, to be completely clear, using the rattle gun to take off both the starter clutch and the alternator rotor works ok ?
Thanks,
Brian
EDIT : ignore that, tried it on the alternator and all was good.
Do not walk behind me, for I may not be leading.
Do not walk in front of me, for I may not follow.
Do not walk alongside me, for the path may be narrow.
Just piss off and leave me alone.
greenman43 is offline
post #7 of 9 Old 08-21-2010, 10:08 PM
dsabat's Avatar
Better yet, leave the cam chain guide in place, and turn the head 90 degrees and pull. No need to remove anything below the head gasket.
dsabat is offline
post #8 of 9 Old 08-22-2010, 06:31 AM
gazx10's Avatar
head removal
thats the way i did it.
gazx10 is offline
post #9 of 9 Old 08-22-2010, 07:39 AM
Gen 5 Now!!
08zx10rny's Avatar
i would remove the cam chain guides. its only 1 pin on 1 and 1 bolt on the other. they only get in the way when they are in place. then you only have to lift the head a little bit. just enough to get over the dowel pins between the head and crankcase.
GEN 5!!!
08zx10rny is offline
Question regarding plastic removal readeth The ZX-10R 9 01-08-2009 09:04 PM
Airbox Removal 05 and Gasket question gruntbull Performance and Tech 9 05-15-2008 08:03 AM
Stock exhaust removal question dbltakeZX10 Performance and Tech 15 08-05-2007 12:34 PM
kleen air removal question chicane Performance and Tech 16 02-27-2007 12:02 AM
Exhaust Servo Motor Removal Question Larry Grogan The ZX-10R 1 02-27-2006 10:04 PM
