Head Gasket - Kawasaki ZX-10R.net
post #1 of 6 Old 07-10-2010, 11:19 AM Thread Starter
Bayboy's Avatar
Send a message via Yahoo to Bayboy
Head Gasket
How do you know if yours has gone bad? What are the symptoms?
YES, I KNOW YOUR BIKE IS FAST............ BUT IS IT FAST WITH YOU ON IT!!!!
Bayboy is offline
post #2 of 6 Old 07-10-2010, 11:41 AM
Gen 5 Now!!
08zx10rny's Avatar
lossa of power, antifreeze in your oil, burning oil, oil leaking from bottom cylinder head
GEN 5!!!
08zx10rny is offline
post #3 of 6 Old 07-10-2010, 11:45 AM Thread Starter
Bayboy's Avatar
FUCK!!! I goy none of that goin on but my bike still is runnin to frickin hot!!! Would a map that is to lean cause it to run hot?
Bayboy is offline
post #4 of 6 Old 07-10-2010, 11:55 AM
clutch master's Avatar
Yes. Are you still all stock or you had major mods done?
The clutch is your friend
clutch master is offline
post #5 of 6 Old 07-10-2010, 03:41 PM
Gen 5 Now!!
08zx10rny's Avatar
yes a map to lean would make it run hot. could be thermostat, could be temp switch, could be water pump. what temp is the bike running at?? in hot weather 215 degrees is not uncommom.
GEN 5!!!
post #6 of 6 Old 07-10-2010, 04:37 PM
Guilty by association
CP10R's Avatar
how hot is it running? does it overheat immediately? Have you checked your air filter? it may be choking.
General "Mad Dog" Mattis
CP10R is offline
08/09 kit cam and head gasket flashf3 Performance and Tech 3 03-26-2010 01:48 AM
Gen 2 head gasket Murtagh1 Performance and Tech 3 06-24-2009 08:54 AM
WTB Head Gasket for 07 afskypilot Vendors deals 1 03-10-2009 09:09 AM
Need 3mm head gasket... on1whl Wanted: Buy or Trade 0 09-27-2006 05:28 AM
cam and head gasket jjfrantz Vendors deals 2 08-31-2006 11:07 PM
