having a Banjo bolt issue with Russell SS lines (08 zx10) - Kawasaki ZX-10R.net
post #1 of 4 Old 06-29-2010, 12:38 PM Thread Starter
swing lo's Avatar
ordered some russell lines that work from an 06-10 zx10r but the factory banjo bolt isn't long enough to run through both banjos and into the M/C.
So obviously the stock lines go from one line then split into two at the triple tree which is why my bolt isn't long enough.
Where do I get a banjo long enough to fit the bill?
Thanks
swing lo is offline
post #2 of 4 Old 06-29-2010, 12:54 PM
Sebastian1000's Avatar
A local motorcycle shop? A local brake shop? A local fluid power shop?
Personally, I would just order the right one...but I am guessing time is of the essence?
1976 250 Elsinore Sold
1997 600R Sold
1976 KZ 900 Sold
2003 1500 Meanstreak Sold
2006 DL 650 Sold
2002 919 Hornet Sold
2004 ZX-10R
Sebastian1000 is offline
post #3 of 4 Old 06-29-2010, 04:13 PM Thread Starter
swing lo's Avatar
yeah I ended up getting a longer one from a local shop. You would think they would start adding a longer bolt to the kits but whatever.......
swing lo is offline
post #4 of 4 Old 06-29-2010, 04:35 PM
themightymezzo's Avatar
My Goodridge kit came with one.
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
Banjo Bolt Leaking??? dsingersoll Performance and Tech 8 05-03-2010 02:38 PM
Banjo Bolt jryanfallon The ZX-10R 3 04-07-2010 08:45 PM
Banjo Bolt RDLYN13000 Performance and Tech 2 03-08-2010 06:42 PM
Pressure switch banjo bolt RDLYN13000 Vendors deals 1 12-14-2009 03:18 PM
Russell Brake lines Frankyoz Performance and Tech 3 07-25-2005 06:23 PM
