has anyone fit a gen2 damper on a gen1? - Kawasaki ZX-10R.net
post #1 of 2 Old 04-27-2011, 02:42 PM Thread Starter
BSL
BSL's Avatar
What does it take to make a stock 2006 ohlins damper fit onto a 2004 zx10?
Thanks
BSL is offline
post #2 of 2 Old 04-27-2011, 06:43 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
All you need is a fork tube clamp that can be ordered from any shop or online BUT the stock ohlins dampers from the 2nd gen are known to suck balls and most have them rebuilt by Dan Kyle. but if you can get one for cheap then i'm 99% sure that the tank mount bracket will fit but you just need the fork tube clamp for the other end of the damper to attach to.
TMY10ER is offline
Will a Gen2 Rim fit on a Gen1? zx10chen The ZX-10R 7 01-29-2011 02:27 AM
gen1 fairings on gen2 edouble The ZX-10R 0 05-04-2010 06:41 AM
Damper mounts the same on gen1 and gen2 ? Lucky10R The ZX-10R 5 06-30-2008 02:44 AM
gen2 shock on a gen1 .... grunty-motor Performance and Tech 7 12-25-2007 09:58 PM
08 10R Gen1 vs Gen2 Deer Elk The ZX-10R 82 10-20-2007 05:27 AM
