Has anyone else received this PC III? - Kawasaki ZX-10R.net
post #1 of 13 Old 08-06-2010, 12:08 PM Thread Starter
zeerex's Avatar
I ordered a Power Commander III USB a while back for my 2007 ZX-10. The part # for this unit is #222-411, as those who have one know. I ordered directly from Power Commander and they sent me part #222-410. The PCIII had a small sticker on it that stated "222-410 for 222-411". Why would they send this? Has this happened to anyone else? Furthermore, when you log onto the PC website, there is no part #222-410. WTF!! Thanks...
zeerex is offline
post #2 of 13 Old 08-07-2010, 03:52 AM Thread Starter
zeerex's Avatar
Anyone?
zeerex is offline
post #3 of 13 Old 08-07-2010, 04:54 AM
Licensed Dist of HaterAde
TMY10ER's Avatar
Not sure if this has anything to do with the original question but i do know that like on gixxers back in the 01-03 models powercommander will have a different part # for the 600 01-03 the 750 00-03 and the 1000 01-02 but yet it's the exact same unit with a different sticker on it. the commanders are compatible and interchangable even though when i asked tech support they stated that they numbered the commanders like this for "inventory purposes" as long as the unit they sent you plugs n plays then there shouldn't be a problem BUT it is strange that the part you recieved isn't even listed on their site.....i'm sure someone else with a 3rd gen will chime in sooner or later and sorry if my post didn't help or even apply to the question.
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #4 of 13 Old 08-07-2010, 11:27 AM Thread Starter
zeerex's Avatar
I appreciate the response and I'm probably just gonna go for it and see how it runs. I can always take it out if there's a problem. Although I'm sure it will be alright, it's just wierd. When someone is looking to beef up performance on any vehicle, and the company shows one part number and sends another stating it's the same thing, it just puts a bad taste in your mouth. That's not what I ordered. Just makes me wonder. Thanks again..
zeerex is offline
post #5 of 13 Old 08-08-2010, 01:34 PM
justins07zx10's Avatar
It will work that is what is on mine. i think that was the part number for the zx14 if im not mistaken.
Green 2011 70" its stock! Lol
justins07zx10 is offline
post #6 of 13 Old 08-08-2010, 01:58 PM Thread Starter
zeerex's Avatar
Thanks for the response, Justin. I went back on the Power Commander website after you stated it was the part number for the ZX-14. The part numbers are different. Part #222-410 remains a mystery. At least I have some comfort with you saying it works on the '07 ZX-10...
zeerex is offline
post #7 of 13 Old 08-08-2010, 09:26 PM
TENN10's Avatar
Images: 145
I've seen that happen before years ago.
If it concerns you, just give dynojet a call. They have always been very helpful and willing to answer question in the past.
TENN10 is offline
post #8 of 13 Old 08-09-2010, 01:22 AM Thread Starter
zeerex's Avatar
Again, thanks for the responses. I don't know if it's really a concern more than just wondering if it's happened to anyone else. Dynojet/Power Commander are the ones that sent it to me. They'll back their stuff up and I'm sure it will work just fine. As their sticker states "222-410 for 222-411". I was just curious. I may just give them a call and ask. Thanks again!!
zeerex is offline
post #9 of 13 Old 08-09-2010, 09:49 AM
macdaddy3's Avatar
I just checked mine on the 07' and it is the same. It says PN: 222-411 on the bottom, but on the side there is a smaller sticker that states "222-410 For 222-411". The only problem I have had with my bike since I installed the commander is a charging concern. The bike would cut out intermittently at first. I re-programmed the Power Commander and it seemed to have stopped. Then one day, the bike just cut out while I was riding it and I found that the battery was dead. I diagnosed a bad rectifier bridge and stator coil. I replaced them, as well as the battery and it seemed fine. I then left it to sit over winter with no battery tender or anything on it and in the spring, the battery was dead again. It was only about a month or two in between so I figure I have a parasitic load or excessive amperage draw or something. I replaced the battery again and out of necessity, I now keep a battery tender on it if I leave it over night. I think it might be the Power Commander because it seems to lose it's memory. I say that because it backfires on decel. I will re-map it with the same map every time and it always runs fine at first and then after a few weeks it will start backfiring again. Re-map it, then the same thing over and over. I am going to get in there with my laptop and see if it even registers a map in it right now. I also need to find a shunt so I can check the amperage draw with the key off.
BE AN INSPIRATION TO OTHERS AND YOU CAN DEEM YOURSELF A USEFUL PART OF SOCIETY.........
macdaddy3 is offline
post #10 of 13 Old 08-09-2010, 09:57 AM
zx10Duran's Avatar
I bought a PC for my zx14 and I got the -411 which is for the zx10 and I installed it with no issues runs great!
lotta newbies, where did all the regulars go?
zx10Duran is offline
I Finally received my 08' greenfury The ZX-10R 32 03-17-2008 10:14 AM
Has anyone received their 08 yet in Canada?? greenfury The ZX-10R 11 02-08-2008 04:39 PM
Just received my parts for the Nissin mod and have ??? Papabear Performance and Tech 11 11-22-2007 12:44 PM
Just received my seat cowl, but... blackisfaster The ZX-10R 25 03-06-2007 05:12 AM
