Hard to start - Kawasaki ZX-10R.net
post #1 of 7 Old 05-12-2007, 02:18 PM Thread Starter
Kawtipper's Avatar
Hard to start
I have a 05 and it seems like since i put my aftermarket pipe on it is really hard to start. When it's cold i have to hit the button about twice and if it is hot and i try to restart it it takes like 4 or 5 times. Like i said before i have a slip on exhaust (Racefit) and a power commander but i haven't had it mapped yet. If anyone has any suggestions i would appreciate it.
Kawtipper is offline
post #2 of 7 Old 05-12-2007, 09:57 PM
FAF
Rent this space
Whens the last time you changed your plugs?
FAF is offline
post #3 of 7 Old 05-13-2007, 10:42 AM
like he said,plugs, or it could be like my buddy when he first put on a pc on his bike it could be a little too lean or rich on start up plus make sure to let you fuel pump cycle completely before starting.
cracker10r is offline
post #4 of 7 Old 05-13-2007, 10:47 AM
chrisbsvc's Avatar
checked idle speed? Usually even slipons will lower your idle speed. Makes the starter motor spin over longer before it fires. Set it somewhere between 1,100 and 1,300 and see if it makes a difference.
chrisbsvc is offline
post #5 of 7 Old 05-13-2007, 01:02 PM
Larry Grogan's Avatar
Images: 14
After I did my pipe the bike would start easier if I pushed the start button while the pump was still priming. Try both.
We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm
Larry Grogan is offline
post #6 of 7 Old 05-14-2007, 12:57 AM Thread Starter
Kawtipper's Avatar
Changed the plugs about 3 months ago and no difference.
post #7 of 7 Old 05-14-2007, 09:58 AM
FAF
Rent this space
Try zeroing the throttle position in your PC111 and get a good idle, 1100RPM,s should be a good number, you may have to lean the engine out a little, but start with the TPS first.
FAF is offline
no start solarbeast06 The ZX-10R 12 03-22-2007 07:14 PM
Where did it all start? thrill The Out House 6 01-25-2007 05:48 AM
To start or not to start................ Travis1000rr06 Performance and Tech 4 01-02-2007 01:30 PM
Hard Evidence for a Hard Break-in BBaxR6 The ZX-10R 29 06-28-2004 06:51 PM
