Gen 1: 2004-2005 Handling Issues - Kawasaki ZX-10R.net
post #1 of 20 Old 01-21-2011, 12:30 PM Thread Starter
DGA
DGA's Avatar
Handling Issues
Hey there,
I've got some handling problems with my '04 ZX10. After a certain lean angle she goes from feeling stable and planted to just downright floaty and very vague. I still think this was part of the equation to my low side at that track last September.
A buddy of mine took the bike out after the crash to see if everything was straight. He is a bike mechanic and an ex racer, so I trust his input. He said she was dead stable at 150+, but handles downright weird. I've ridden the bike on the street since and this feeling persists. I thought it was in my head, but my Speed Triple handles just fine from scraping one peg to the other.
The suspension is sprung and valved to my weight and set up for the track. Everything else on the bike is stock sans the GPR steering stabilizer and ZX14 brakes.
When I brought my old suspension to the shop the guy said I had a ZX6 shock on the back. So in my mind there is a possibility that I have a ZX6 lower dog bone, or whatever you want to call it, mount on the bike. What is the difference between the ZX10 one and ZX6 one?
Second, how much of a shim should I use on the back? I think I have about 20mm now.
Should I have the steering stabilizer rebuilt after that crash?
I really don't trust this bike at the moment, because that last crash hurt after some ripped knee ligaments. I would like to get this figured out since I love this bike and don't want to get rid of it any time soon.
Thanks,
-D
DGA is offline
post #2 of 20 Old 01-21-2011, 01:16 PM
RuneCNR's Avatar
Sounds weird... I trust you have checked the frame for cracks and all the engine mountings? And wheelbearings?
RuneCNR is offline
post #3 of 20 Old 01-21-2011, 01:38 PM Thread Starter
DGA
DGA's Avatar
^^^Thanks. That is one of my fears. I think it's time to set my project bike aside and rip into the ZX to see if there are any cracks in the frame.
DGA is offline
post #4 of 20 Old 01-21-2011, 02:23 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
The thing with the ZX6 swap is it raises the rear a few mm for better iniatial turn in i believe. i know that mine was acting weird a while back after i had done some work on the front end and OR10R sent me this video that helped alot and fixed my problem.i know it seems like something very dumb and simple BUT it seems to be a slight issue at times with the 1st gen. hope it helps and that it's NOT a tweaked frame!!
http://www.onthethrottle.com/howto/p...-installation/
TMY10ER is offline
post #5 of 20 Old 01-21-2011, 02:33 PM Thread Starter
DGA
DGA's Avatar
Thanks TMY. I do this every time I take the front wheel off. Loosen the pinch bolts and pump the front a few times so the front forks move to their proper location, than tighten. But it will not hurt to do it again. Got to keep reminding myself to start with simple things first.
I've already got the rear raised with a shim, but I just might take it out and see what she does without it.
DGA is offline
post #6 of 20 Old 01-21-2011, 02:57 PM
TMY10ER's Avatar
Just hoping it's nothing major man......there's no chance that the forks got tweaked or anything right? there's nothing worse then an ill handling bike!! except maybe not knowing why she's acting that way?
TMY10ER is offline
post #7 of 20 Old 01-21-2011, 04:02 PM
RuneCNR's Avatar
Maybe also check that the forkyokes? The ones holding the forklegs aren't tightened too much. That could also prevent normal fork travel.
RuneCNR is offline
post #8 of 20 Old 01-21-2011, 04:43 PM Thread Starter
DGA
DGA's Avatar
Me too. The bike suffered almost no damage at all. Rashed bottom and mid fairing and that is it. Still dead stable in a straight line and not the smallest of wiggles if you take your hands off the bar at 120+.
I'll take the shim out of the rear and take all of my tools with me for the first track day and see what shakes out.
Thanks for the heads up Rune. I torqued them to spec last time I put them in, but I'll re torque them just to make sure. I always torque everything to spec, but who knows.
DGA is offline
post #9 of 20 Old 01-22-2011, 04:54 AM
RuneCNR's Avatar
No problem hope you get it to run right!
Do you have a torque spec list? I had one for my old bike. But I need one for the Gen 1.
RuneCNR is offline
post #10 of 20 Old 01-22-2011, 05:08 AM
All show and all go 10r
JLG0987's Avatar
When was the last time your suspension was serviced in miles?
JLG0987 is offline
Gen 1 handling issues are solved. OmegaX The ZX-10R 32 10-04-2009 04:35 PM
ZX-14 Handling magzx12r ZX-14 Discussion 14 07-23-2008 02:03 AM
Handling? Mustard Track 0 10-10-2007 07:59 AM
Handling Issues casey Performance and Tech 1 07-27-2007 08:41 AM
Handling zx7rr The ZX-10R 10 07-03-2007 01:46 AM
