Gen 4: 2011-2015 Guhl Motorsports reflash with removing secondary butterflies - Kawasaki ZX-10R.net
post #1 of 5 Old 05-30-2012, 10:36 PM Thread Starter
Has anyone done this? I have searched and seen that if you take the secondary butterflies out your lose traction control. Is this true? Also will the bikes A/F ratio be way off if i take the secondaries out with the reflash?
Roadrage13 is offline
post #2 of 5 Old 05-30-2012, 10:47 PM
teedub21's Avatar
There's no point. Don Guhl's flash takes care of the secondaries by opening them sooner and keeping them open longer. Leave them in.
teedub21 is offline
post #3 of 5 Old 05-31-2012, 08:17 AM
Speed Freak
garth285's Avatar
I have my entire secondary throttle system removed, shafts and all.
You dont completely loose traction control but you loose its 1st line of defense... it will still kill ignition for you.
garth285 is offline
post #4 of 5 Old 05-31-2012, 09:34 AM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
Not sure if thats the one were they state to leave flies in ..
06blackpearl is offline
post #5 of 5 Old 05-31-2012, 12:15 PM
BratNetwork's Avatar
I don't know about the Gen 4 as much, but on my Gen 3 Don told me to leave the flies in as they help increase the velocity of the air in the lower/mid rpm ranges. I had mine out for a bit and on the street I wasn't happy with it, then I put them in again from Don's recommendation and got a flash from him and its definitely better in the low/mid than before.
BratNetwork is offline
removing the secondary butterflies on drag bike Bustar Strip 5 02-04-2012 11:55 AM
Removing secondary butterflies bullet4 The ZX-10R 2 01-08-2012 09:14 PM
removing secondary butterflies M109R Performance and Tech 3 03-17-2010 09:43 PM
Removing the Secondary Butterflies Zuperman Performance and Tech 15 04-01-2009 11:00 AM
Questions on removing secondary butterflies on TB??? on1whl Performance and Tech 14 01-13-2006 07:21 AM
