GSXR600 gearing question - Kawasaki ZX-10R.net
post #1 of 8 Old 07-31-2007, 08:59 PM Thread Starter
Accountant in training.
Deer Elk's Avatar
Question GSXR600 gearing question
Fact or fiction?
This guy claims that his 2006 GSXR600 with -1/+2 gearing can go 169.5 mph @ 14,300 rpm... Supposedly radar verified... Also claims his speedo was showing 179 at the time. Stock I think is just over 160 mph. He has a slip on, Yosh EMS cube, and a 'hotter' cam...
I think it is BS, but I wanted a second, third, fouth.... opinion. The gearing change should take at least a dozen mph off the top end right?
Thanks.
Chris
Deer Elk is offline
post #2 of 8 Old 07-31-2007, 09:32 PM
ibescott's Avatar
Send a message via AIM to ibescott Send a message via Yahoo to ibescott
I don't know about how much it should take off but it will drop it for sure. Something doesn't seem right...
https://www.facebook.com/scott.d.barraclough
2005 PBO ZX10
2002 Blue Honda Goldwing
Sold 2004 Blue ZX10
Sold 2006 Blue ZX14
ibescott is offline
post #3 of 8 Old 07-31-2007, 09:49 PM
Sounds like a hot fresh steaming load of BS to me, Chris.
Is this a guy off the Sportrider Board? Because you know, EVERYBODY on the internet has superhuman abilities of some sort........
casey is offline
post #4 of 8 Old 07-31-2007, 09:50 PM
That guy is smok'n some good green!! Most 600's are gonna run true speed of about 155-160 max with oem gearing. The mods he has done will not add max speed in any way shape or form. Infact the gearing he has done will lower his max speed.
I would surely beg to bet his GSXR600 with a -1/+2 combo will only touch the 140-145 max speed at best.
If he indeed feels he can go that fast......find a stretch of road and roll on gently up to speed with your ZX10. I would beg to bet he has no more left when your speedo is rolling past 140'ish.
06450F is offline
post #5 of 8 Old 07-31-2007, 11:08 PM Thread Starter
Deer Elk's Avatar
Thanks. That is what I thought...
I could see where a little lower gearing could add mph, assuming that he couldn't pull stock gearing. But going as low as he did, I doubt if it can go that fast. Using this calculator: http://www.dansmc.com/mc_software1.htm Stock the 10R is geared for a theoretical 195. Puting in the -1/+2 gearing I get something in the 175 neighborhood.... I don't think a 600 will lose 20 mph, but 12-15 should be close.
Just like Casey said... A big pile of steaming BS...
And yeah, 06450F, a little roll on with him should clear things up. Or like you said, just pace him until he is bumping the rev limiter in 6th and see where I am at on the 10.
I'll have to let him know what others think. Thanks again.
Chris
Deer Elk is offline
post #6 of 8 Old 08-01-2007, 12:49 PM
Micron05rr's Avatar
I would like more information about this super 600 but, from what you posted, impossible. My 05zx6rr geared -1, +4 at the strip is just about touching the rev limiter at the top of 6th gear going through the traps. My MPH is usually right around 129-130 measured by the track timing system
(Speedo showed 167-170mph) Even only -1, +2 with his supposed mods, maybe 135-140 actual mph.
Micron05rr is offline
post #7 of 8 Old 08-01-2007, 01:38 PM
nite-ryder's Avatar
No way possible. Unless this guy weighs 4 pounds. He's seriously smokin' something!! Gearing down will cut his top end.
What can I say...I like the factory bikes!
nite-ryder is offline
post #8 of 8 Old 08-01-2007, 04:44 PM
FAF
Rent this space
145mph would be good going.
FAF is offline
Another Gearing Question Skip114 Performance and Tech 3 01-08-2007 12:28 AM
06 Gearing Question Skip114 Performance and Tech 1 01-05-2007 03:15 PM
I bought an 04 GSXr600 OmegaX The Out House 3 12-25-2006 10:25 AM
tire and gearing question whytedude The ZX-10R 14 05-12-2006 12:34 AM
2005 Gsxr600 burgerkin Pictures and Videos 14 10-29-2004 01:23 AM
