Grease on a stick coil??? - Kawasaki ZX-10R.net
post #1 of 4 Old 05-12-2011, 05:57 PM Thread Starter
TexasRider's Avatar
Was just glancing through my gen2 service manual, and in the electrical chapter where it explains installing the stick coils, it says 'apply grease to stick coil' Anyone have a clue why and what kind of grease?? Is it for electrical insulation purposes?? And do you coat the whole coil??
Faster than a drunk snail on valium!
07 zx10r- stolen
New bike...07 GSXR1000..BMC filter, LOR slip on, 520 conversion with -1, speedohealer, pc3 custom map with xtre settings, Galfer superbike lines front, galfer sportbike line rear, shorty levers, Yami R1 throttle tube for 1/5 throttle, PAIR mod, exhaust valve gone, ecu flashed.
TexasRider is offline
post #2 of 4 Old 05-12-2011, 06:15 PM
Teeks's Avatar
You just use a little bit of dielectric grease on the end (inside) of the coil boot. Using some on the boot for ease of sealing the boot to the plug, and getting no voltage leakage, and to seal the end of the boot from moisture and contamination. Its just a good extra measure, however it is not necessary by any means.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #3 of 4 Old 05-12-2011, 06:24 PM Thread Starter
TexasRider's Avatar
Ah jus like a plug wire on a car/truck. I see. The manual was very unclear about that...lol!! Thanks! lol
07 zx10r- stolen
post #4 of 4 Old 05-12-2011, 09:21 PM
gazx10's Avatar
grease provides a moisture barrier and allows for easier removal of tthe coil later. mine were stuck bad in the valve cover first time removed.
gazx10 is offline
Stick coil removal ride2ride The ZX-10R 23 08-26-2011 10:44 PM
Gen 2: coil packs? TexasRider Performance and Tech 11 07-05-2011 01:40 PM
Copper grease - use it! Fluke General Motorcycle Discussions 7 03-30-2008 03:27 PM
That grease that comes on a new chain... TI10 The ZX-10R 15 04-18-2007 07:20 AM
Throttle grease or no grease? conspiracy Performance and Tech 10 09-25-2006 11:19 PM
