Gen 4: 2011-2015 Graves header diameter - Kawasaki ZX-10R.net
post #1 of 8 Old 07-08-2014, 01:05 PM Thread Starter
Does anyone know what size tubing the graves header uses, and is it the same size all the way through or does it get larger after the first collectors? thanks
(tried emailing them but have not gotten a response)
1upmoto is offline
post #2 of 8 Old 07-08-2014, 06:08 PM
I took measurements for someone a while ago and sent them to them on Facebook. I will check and see if I still have that message saved/archived.
If not, I will be replacing the coolant with Engine Ice for my next track day after I get back from Laguna Seca so I'll take them then.
Do you want OD or ID?
ZX10RArcher is offline
post #3 of 8 Old 07-08-2014, 10:50 PM Thread Starter
awesome thanks, and outside diameter will be fine.
1upmoto is offline
post #4 of 8 Old 07-17-2014, 09:12 AM Thread Starter
bump
1upmoto is offline
post #5 of 8 Old 07-17-2014, 11:12 PM
I should have them for you this weekend bud.
post #6 of 8 Old 07-21-2014, 10:16 AM Thread Starter
thanks
1upmoto is offline
post #7 of 8 Old 07-21-2014, 12:25 PM
Sorry didn't get to it. Took the bike out for a quick spin and it started sputtering and throwing FI Code 54 (Ignition Coil 4).
So what time I was going to use to change out the old coolant for engine ice was used finding and troubleshooting my coil problem. (Hint: loose quickshift coil connector. Safety wire all your connectors kids!)
BUT...
I went back through an old Facebook conversation with someone on here where he asked the same thing and luckily the pics were still in there...
post #8 of 8 Old 07-21-2014, 03:16 PM Thread Starter
awesome, I really appreciate it
1upmoto is offline
Gen 2: Axle diameter? TexasRider Performance and Tech 4 02-18-2012 12:20 PM
outer diameter of 07 zx10 lens prtricn04 The ZX-10R 1 10-13-2008 11:51 PM
approx. tire diameter? hesaves0211 General Motorcycle Discussions 6 03-27-2008 04:19 PM
Galfer brake line diameter? Hattori Hanzo Performance and Tech 6 04-07-2007 02:14 AM
Need Bolt Diameter, PLEASE! mach_man_187 Performance and Tech 2 05-12-2006 07:12 AM
