GP Style Shift - Kawasaki ZX-10R.net
post #1 of 10 Old 05-27-2007, 10:20 PM Thread Starter
Images: 31
GP Style Shift
I finally decided to try the GP style shift. I think im going to like it.
Here are a couple of pics I dont think I mangled it up to bad. What do you guys think?
Do you like where im sporting the zx10r.net sticker?
https://zx-10r.net/gallery/displayimage.php?imageid=3285
https://zx-10r.net/gallery/displayimage.php?imageid=3284
flank31791 is offline
post #2 of 10 Old 05-27-2007, 11:58 PM
BANNED
I have been riding the last 15 years with a reverse shift pattern, or 1 Up and 5 down. But when I went to flip the shifter around on my new 10R, it hits the fairing lower and I am not willing to cut the plastic at this time for proper clearance. So now I will have to get use to 1 down, 5 up. That can be very dangerous. Magazine test riders (racers) used to reverse shifts have been know to trash out new testbikes because of this. Go to shift from 3rd to 4th under hard acceleration and accidentaly go from 3 to 2nd instead can be disasterous.
I like 1 Up / 5 Down much better. Easier to push down on the pedal to go faster than pulling up on it. IM surprised Kawi didn't provide adequate clearance for this.
JJ
JimmyJam is offline
post #3 of 10 Old 05-28-2007, 04:18 AM
Depends on what you mean by dangerous.
My buddy switched his GSXR to GP style shift and was 'upshifting' leaving a stop sign and his foot slipped down off the shifter and he stiff-legged the pavement, shattered his knee, destroyed his bike, blah blah blah.
So I guess it's not really the shift pattern that is dangerous, but doing what you are accustomed to doing on a bike you are NOT accustomed to.... is that what you meant to say JJ or did I misunderstand you?
casey is offline
post #4 of 10 Old 05-28-2007, 04:27 AM
thrill's Avatar
Had that setup on an old mach 4 750. But the shift on those was 5 up, was a real pain in the arse for hitting neutral
Bill - GI Pro, Hindle slip on, Smoked screen, ZX14 brakes.... Well, you feel lucky, punk? You shouldn't, this is a 10R
thrill is offline
post #5 of 10 Old 05-28-2007, 08:08 AM
S.ga.rider's Avatar
I had to go back to regular shifting on the aprilia and missed several shifts trying to get used to it again. When I went to the gp style I never missed a shift. It felt more natural to me.
For I am convinced that neither death nor life, neither angels nor demons, neither the present nor the future, nor any powers, neither height nor depth, nor anything else in all creation, will be able to separate us from the love of God that is in Christ Jesus our Lord. Romans 8:38-39
S.ga.rider is offline
post #6 of 10 Old 05-28-2007, 08:12 AM
Andy's Avatar
Images: 25
That looks like a professional cut.
Andy is offline
post #7 of 10 Old 05-28-2007, 09:39 AM
SkyDork's Avatar
JJ
No cut option....
Name:	GP shifter copy.jpg
ID:	36116   Click image for larger version
Name:	GP shifter 2 copy.jpg
#WordCrimes
SkyDork is offline
post #8 of 10 Old 06-12-2007, 12:32 AM
Newfie Bullet
craig_sez's Avatar
Images: 34
HHHmmmm...I like the idea but till i get used to it,i know im gonna forget where i am..
craig_sez is offline
post #9 of 10 Old 06-12-2007, 02:13 AM
Cling's Avatar
I never did like GP shift, my foot has a real problem hitting the downshifts (clicking it up) while under HEAVY braking. It did kind of come in handy on the long right hander before the finish line at Road Atlanta but thats about it.
Cling is offline
post #10 of 10 Old 06-12-2007, 04:13 AM
Macke's Avatar
Images: 40
Send a message via MSN to Macke
Originally Posted by SkyDork View Post
No cut option....
I would prefer to make a small cut in the fairings rather than this option.
The bracket should be in a 90 degree angle towards the shiftrod. If the angle is not 90 degrees, the push and pull forces applied by the shiftrod will not get the full effect.
This means that you will have to apply more preasure to the gearlever to fully engage the gears in the gearbox. This will sooner or later make you miss gears, hit false neutral, and so on.... Maybe not right away, but when you push hard for a long time on the track (which I must assume that you do if you really need the GP-shift pattern), you will get tired and start being sloppy with your gearchanges....
I had this problem with my first racebike. And i was sure that the gearbox was about to give up on me any time. Missed gears and false neutrals... When adjusting the gearlever I noticed that the previous owner had mounted the bracket in the wrong way, and the angle from the shiftrod was far away from 90 degrees. I changed the position of the bracket, and the problem was solved... Shifting was a lot better...
Unfortunatly the missed gears, and false neutrals, had already damaged the gearbox. And I can tell you that repairing the gearbox is a lot more work than cutting away a couple of millimeters of plastic...
If you can't race fast, atleast you can look fast...
Macke is offline
Just did the GP shift mod hangman39 Performance and Tech 64 04-26-2011 03:41 PM
shift style? solarbeast06 The ZX-10R 19 02-12-2007 08:03 AM
06 636 gp shift aussie70 ZX-6R & ZX-6RR Archives 1 05-28-2006 09:11 PM
shift help??? green dragon The ZX-10R 0 06-19-2005 05:28 PM
shift kit greenmeanie The ZX-10R 1 06-21-2004 11:41 AM
