Got the replacement bolts from Sato... - Kawasaki ZX-10R.net
post #1 of 8 Old 01-25-2005, 09:46 PM Thread Starter
Post Whore
El Diablo's Avatar
Got my replacement bolts from Sato today. Not happy with them. Two of them appeared to be better sampless (the two that hold the master cylinder to the right rearset), one is marginal, but better than the original (the one I really needed replaced... the one that holds the heim to the shift pedal... that fell out because I couldn't tighten it), and two are just like the originals were (the two that hold the ankle guard to the left rearset). They didn't send any other bolts (didn't really need any of the others so that was cool) or a replacement collar for the one that fell out with the shift heim bolt.
They basically said in their last reply that their fasteners were top notch and that they recommended "professional installation" of their products, which tells me that they're prepared to say I'm the problem if these don't work. Yeah, I've only been turnin' bolts on cars, trucks, and bikes for, what, 20 years now? Not saying I can't make mistakes, but I do know junk bolts when I see/use them. Well, I'll save them the hassle of avoiding blame and denying fault in their fasteners. I'm going to find replacement fasteners on my own and throw the Sato bolts in the garbage. Just wanted to update everyone on it since I posted in my original thread about the problem. I'll try to take some close up shots of the bolt heads and update the install thread when I have time. Gotta hit the bed so I can get up at 4:00 for work...
Anyway, I still think their rearsets (the base plates, step plates, and pegs) are great pieces. Absolutely top notch in fit, finish, and function. Just be prepared to find/buy your own fasteners if you buy Sato rearsets and don't like what they send with them. Well, that or find a "professional" that can outsmart their fasteners. Kinda sucks seein' as how I paid what I paid for the Sato pieces expecting top notch quality throughout. Oh well, I'll live. I've paid more for less in the past I guess...
"Bottom line, when I'm on that bike, it's just me and God...And He better be holding on."- Stillie on SSB
Si vis pacem, para bellum...
El Diablo
El Diablo is offline
post #2 of 8 Old 01-25-2005, 09:51 PM
that's a bummer... I didn't have any problems with any of their fasteners.
jeech is offline
post #3 of 8 Old 01-25-2005, 09:57 PM Thread Starter
Post Whore
El Diablo's Avatar
Looks like maybe a QC issue from the bolt manufacturer. Like I said, two of the new ones were good, unlike the originals. One was better, but still not "right", and two were the same. Looks kinda like pot luck. You may get good ones and you may not. Out of two sets I've not been very lucky.
El Diablo
post #4 of 8 Old 01-25-2005, 11:41 PM
I think I got a good batch. All tightened up to spec without any issues. Now I just need to flip that one heel guard....I knew I'd have to fuck up at least one thing!
NWZX10 is offline
post #5 of 8 Old 01-26-2005, 07:25 AM
If putting the heel guard on upside down is the worst of it, then I would consider it a successful install.
jeech is offline
post #6 of 8 Old 01-26-2005, 08:42 AM
MIA Post Whore
miykl's Avatar
El D- Just out of curiousity, are you using ball end hex drivers? I've found that they can tear up a hex bolt that's the slightest bit soft in a quick hurry.
miykl is offline
post #7 of 8 Old 01-26-2005, 06:10 PM Thread Starter
Post Whore
El Diablo's Avatar
Good point but I don't even own ball end hex/allen wrenches.
El Diablo
post #8 of 8 Old 01-26-2005, 07:08 PM
Heel guard fixed today. Then I found I lost my first bolt nut. My license plate bracket (aftermarket) that I replaced the stock one with dropped a nut. luckily the other side stayed in place. Time to go through the entire bike and tighten stuff up.
NWZX10 is offline
Sato Rearset Install w/pics>>> El Diablo Performance and Tech 80 01-21-2005 07:27 AM
Sato Rearset Install w/pics>>> El Diablo How To... 2 01-11-2005 12:56 AM
Replacement hardware {Nuts & Bolts BackMarker The ZX-10R 2 10-19-2004 03:14 PM
Sato S/O Review and Dyno Results TAFB The ZX-10R 55 10-14-2004 07:44 PM
