Got mah bitch dynoed today and.... - Kawasaki ZX-10R.net
post #1 of 32 Old 08-10-2010, 01:53 AM Thread Starter
Kawawog's Avatar
Send a message via MSN to Kawawog
It made 175.09hp and 80.75ft lbs of torque atw with a yoshi R55 slip on,akra link pipe,pcv,k&n filter and custom map.. No other mods
Heres the dyno sheet:
Im quite happy with this figure considering im still running the stock headers and cats and have minimal mods..
The guy dyno'n it told me it was a strong engine,considering that he recently dynoed a 1000cc blade with full exhaust,cams, pc,air filter that made around the same figure
Gotta love 10's
Kawawog is offline
post #2 of 32 Old 08-10-2010, 02:11 AM
kawsquid23's Avatar
Nice bro! I cant wait to get my header, and stacks to get mine dyno'd. Seeing this give me hope for my mods lol. Nice to finally have sum real numbers running different set ups to see what works best together
'07 Special Edition Yosh carbon bolt on exhaust, K&N, TRE, PowerCommander, NGK Plugs, .45mm head gasket, port and polished head, DID chain, Vortex sprockets(stock gearing) 520 conversion, blacked out windscreen, rear seat cowl, carbon mirrors, passenger pegs removed. :deathmeta
kawsquid23 is offline
post #3 of 32 Old 08-10-2010, 08:48 PM
These posts make me really frustrated....
I had an '04-
It made 142 HP stock
I put on a Yosh TRS slip on it made 150.7
I then put on a full Hamaguchi system and it made 151.75..
Now I just bought a 2008-Had it tuned on Saturday.
It made 142 bone stock-
With Arata Slip on it made 151HP-Full custom map,PERFECT AF @13/13.6 Across the Range..
On a DynoJet Dynameter
WTF????
ILOAD2 is offline
post #4 of 32 Old 08-10-2010, 10:46 PM
evallarta1's Avatar
I had an '04-
WTF????
Every dyno is different. You could go to one and pull 150hp and go to a completely different one the same day and pull 180hp. The numbers aren't as important as are the a/f ratio and your curve.
Velocity Calibrations
evallarta1 is offline
post #5 of 32 Old 08-11-2010, 12:14 AM
badassjake's Avatar
HP numbers are nominal...percentage of net gains is what tells you where your money is best spent...15% gains is 15% on any dyno, anywhere, fact.
Perfect A/F and a nice power delivery, if this is not enough, spend more money...if said dyno told you it was 180hp or 150hp, regardless if it's not enough it isn't.
J
badassjake is offline
post #6 of 32 Old 08-11-2010, 08:29 AM
kawsquid23's Avatar
another thing on bikes is the good dynos will have forced air so the bike isnt sucking for air that isnt there, but has air pushed into it, thatll come into play a lot, do sum searching before you et it dyno'd to find the best guy and dyno. a slip on or exhaust wont get you anywhere amazing over stock power, like he said, spend a little more to put in your bike and youll be looking at those numbers or maybe better!
Live Fast, Ride Hard!
post #7 of 32 Old 08-12-2010, 01:35 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
when they do yer runs..Get them to measure in sae and NOT STD....makes a diff..
craig_sez is offline
post #8 of 32 Old 08-12-2010, 04:37 PM
BANNED
Gotta love 10's
Thats a GREAT dyno run, and typical of what is for all intents and purposes, a race tuned engine from the factory once you trash the can and boom box. Normally I am a K&N hater, but not on this model. It works. I have done a lot of testing on these Gen 3 filters.
Many, actually a lot of Gen 3 owners post these type of mid 175+ numbers after an exhaust change, Power Commander and aftermarket filter.
My last dyno run a few months back produced 180, but that was also with an ignition module, and BST wheel with ceramic bearings and full Akra system, PC3 and cam timing.
I have race cams, springs and thin head gasket left "in stock" , though I may not even bother as this Mofo pulls like no other already.
MagicMavis is offline
post #9 of 32 Old 08-12-2010, 05:38 PM
dirt ninja's Avatar
Images: 9
You actually have a intake race cam left? I remember you selling one to a member on here.
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
post #10 of 32 Old 08-12-2010, 05:58 PM
BANNED
That wasn't the 08 intake race cam I sold. It was the 06/07.
The 08 race intake is basically the same (same lift) as the stock 08, just 4 more degrees and i really cant see that doing much below 10K RPM's, so I am not sure I will even bother with it.
Dynoed my 07 today, what do you think? TMAC Performance and Tech 11 11-14-2009 09:09 PM
Dynoed my 08 today.. tasos Performance and Tech 39 10-28-2008 03:18 PM
Dynoed my turbo 10 today Vince10R Performance and Tech 95 06-12-2008 11:21 PM
Got my 04 dynoed today DareDevil The ZX-10R 16 01-14-2007 01:00 PM
Dynoed My 10R Today. kneedragger The ZX-10R 33 02-27-2006 04:09 PM
