Good article on dynos. - Kawasaki ZX-10R.net
post #1 of 10 Old 07-18-2007, 03:08 PM Thread Starter
FAF
Rent this space
Garth will love this one.
http://www.factorypro.com/magazine/m...ojet_dyno.html
FAF is offline
post #2 of 10 Old 07-18-2007, 04:45 PM
Micron05rr's Avatar
Nice find. Thanks for sharing
Micron05rr is offline
post #3 of 10 Old 07-18-2007, 04:47 PM
1rocket69's Avatar
Location: Used to be Candler, NC/ Then HELL in Del Rio, Tx/ Now Blaine, WA
Nice read, thats some good spreads on HP.
Wondering in HP limited classes how much head scratching goes on trying to tune a bike to close to class limit then getting to the track and having to retune it cause your high.... or worse yet have it ok in the morning, then fail a post race Dyno.
Liberal-- A person who is so open minded that their brains have fallen out.
1rocket69 is offline
post #4 of 10 Old 07-18-2007, 04:49 PM
inappropriate
hesaves0211's Avatar
Images: 67
thats good info
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #5 of 10 Old 07-18-2007, 04:49 PM Thread Starter
FAF
Rent this space
I have been to a couple of Moto ST races and seen a lot of head scratching with the techs after dyno runs.
FAF is offline
post #6 of 10 Old 07-18-2007, 07:37 PM
Speed Freak
garth285's Avatar
ahhh thank the lord someone has finally put out some more info of this! I wish everyone knew about this. Great find FAF!!!!!
garth285 is offline
post #7 of 10 Old 07-18-2007, 10:53 PM
Speed Freak
garth285's Avatar
Well I was able to read threw the whole thing and I am truely glad someone finally published something like this.....believe me I love dynojet stuff liek power commander ign module and HUB but their dyno's have always varied way to much and since i have been operating a factory pro dyno which we have in a fully mobile set up capable of doing atvs as well. the results are always similar. we have had bike after bike come up and have gotten similar results like with r1's we see the same exact power drop mid range and they produce same power stock vs stock.
From what I understand dynojets got real popular with the vmaxx when they claimed 100hp or something and everyone was amazed but it was on a dynojet which is basically an accelermoeter.
In the future if i own my own shop I will try and get a factory pro, I love them and they show actual numbers!
garth285 is offline
post #8 of 10 Old 07-19-2007, 11:09 AM Thread Starter
FAF
Rent this space
I think the article said a lot in regards to what the consumer wants, I looked at factory pro dynos when I had my shop in Jupiter and it really was the way to go, but customers in general dont want to see low numbers , most of the time they just want a dyno sheet and have bragging rights.
There is a strange mentality with the sportbike population in general , its very rare you will see a Muzzy pipe on a Gixxer ,although Muzzy do their research , and the same for Yoshi on Kawasakis, you see a little more of that , but they have been branded because of their racing associations, even if the pipes make better power .
Very strange.
FAF is offline
post #9 of 10 Old 07-19-2007, 11:41 AM
Very strange.
Absolutely. When I did the first dyno on my 10 with a PCIII and TRE I expected it would be higher than 150 because that is what it should be stock. I was surprised it only made 149hp and 74 torque. So now when I hear someone saying "I got 180hp with pipes and a PCIII." I say
I think the article alluded to the fact that these are really only effective benchmarking tools for modifications. The real test is on the track as to how well the power that actually exists is applied and modified by the map. Dynoing for max power may leave you flat in some gears. I am sure at pro levels they are tuning at a track specific level just like gearing changes for a given track. The benefits of this seem pretty obvious.
Good find FAF.
pr0phet00 is offline
post #10 of 10 Old 07-19-2007, 11:47 AM Thread Starter
FAF
Rent this space
This was my reasoning for going with a programmable Lambda closed loop, get a good dyno baseline and then do my own tweaks with a proper programmable ECU.
FAF is offline
Good 06 article (explained the tire situation) 06450F Performance and Tech 6 01-29-2007 08:26 AM
Here is a good article for you married people S.ga.rider The Out House 20 01-08-2007 03:10 AM
Any zx14 Mag. dynos tests out yet?? Wicked Webby ZX-14 Discussion 24 05-05-2006 11:32 AM
Sport Rider dynos the 6R Andy ZX-6R & ZX-6RR Archives 16 03-29-2005 12:01 AM
