going up 1th front? - Kawasaki ZX-10R.net
post #1 of 15 Old 04-28-2008, 08:32 PM Thread Starter
inappropriate
hesaves0211's Avatar
Images: 67
going up 1th front? turbo swb
ill be turbo'ing the bike this summer. in between reinforcing the clutch basket and installing stiffer springs id like to modify the gearing to accommodate its stock wheel base. doing so, this should help maintain power delivery and reduce the front from pointing upward upon mild acceleration therefore i will be able to use the turbo more effectively during roll-on's (ultimately owning most other non-turbo'd bikes). i know, its going to be wheelie madness but if its to unappealing ill just buy a cycle concept 3-6 next summer.
fyi, it will primarily be a street bike with little strip time running 5-6psi on stock internals (for the time being).
my question, has anyone had experience running 1 up in the front with a 525 chain? what should the estimated top speed in first be? i dont have any turbo experience, recommendations?
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #2 of 15 Old 04-28-2008, 11:33 PM
silversv1k's Avatar
Images: 44
id say first gear with that should take you way past 100 since they do that with factory gearing, if my guess, true speed in first with a 18t sprocket would be around 105-110 but thats just a guess btw im gonna go book my flight so i can come ride this thing bro
silversv1k is offline
post #3 of 15 Old 04-28-2008, 11:38 PM
ZX-10R_Sinner's Avatar
Yeah...I would think about 110 with the front wheel violently leaving the ground sounds right...
ZX-10R_Sinner is offline
post #4 of 15 Old 04-28-2008, 11:41 PM
http://www.gearingcommander.com/ will tell all about your gearing vs speed.
TN10R is offline
post #5 of 15 Old 04-29-2008, 05:04 AM Thread Starter
inappropriate
Images: 67
thats what i was thinking. ill be selling tickets to ride it for a price but youll have to sign a release for legal reasons ;)
yea, most likely. it will be inevitable. and no matter what i want to hear, ill need to stretch it at least 3'' to use the power. im sure w swb a 1300 will roll on me because i wont be able to put the power to the ground once it boost
post #6 of 15 Old 04-29-2008, 05:13 AM
bluedevil's Avatar
you guys are crazy...there is a limit for First gear by the internals and Redline...do some of you know the fastest bike stock Busa that did well over 190mph can't to 100mph in first gear(like a Stock 10R) and the Busa is equivalent to a -16t ZX10R in first gear?...adding gear good luck you will run out of RPM first but most likely gearing.
bluedevil is offline
post #7 of 15 Old 04-29-2008, 05:18 AM
silversv1k's Avatar
Images: 44
huh are you a lil
post #8 of 15 Old 04-29-2008, 05:24 AM
bluedevil's Avatar
huh are you a lil
meaning not faster that 105mph 1st Gear...yeah maybe i'm sleepy..good luck with that don't forget the transmission.
post #9 of 15 Old 04-29-2008, 05:28 AM
silversv1k's Avatar
Images: 44
y because the internal first gear is limited it doesnt matter what the overall gear ratio is? is that what you meant?
post #10 of 15 Old 04-29-2008, 05:30 AM
bluedevil's Avatar
yep....I think some of you guys that can do over 100mph in first gear are spoiled .
06 - 07 front rim and front master cylinder XXBirdman Wanted: Buy or Trade 1 09-06-2007 05:40 PM
WTB- front tire hugger, RAM AIR, FRONT END swing lo Wanted: Buy or Trade 2 07-10-2007 08:30 AM
'06 Front Rim Fred S Wanted: Buy or Trade 0 04-28-2007 05:01 PM
WTB Front RIm smikels Wanted: Buy or Trade 0 10-24-2005 07:10 PM
What front rim would fit a 10R? 10inja Performance and Tech 2 02-09-2005 09:54 PM
