GiPro changing modes on it's own ??? - Kawasaki ZX-10R.net
post #1 of 5 Old 04-15-2009, 08:00 PM Thread Starter
Drain Fade's Avatar
Ok, I have a fricken weird one. I have a Gipro and a Speedohealer in my '06 and it's acting real freaky to say the least. This morning it was a bit cold and that's when it has a mind of it's own. First it started changing modes on it's own, I didn't touch it but saw it change modes twice while I was riding. Then I hit the button to change the display on the speedo and it changed modes again. WTF ???? Has this happened to anyone ? I guess I'll just call up HealTech and troubleshoot it with them if not....
Drain Fade is offline
post #2 of 5 Old 04-24-2009, 04:14 PM Thread Starter
Drain Fade's Avatar
There's nothing like replying to yourself...anyway, I found out I have a bad GiPro. One is on the way and to anyone out there that needs to disable the GiPro just pull the power cable. It'll go to pass through mode and run like there's no TRE on it. That way you only have to remove the bad one when the new one arrives ;)
post #3 of 5 Old 04-24-2009, 06:46 PM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
Yeah I say its a bad gipro. Im not an electrician wizard but I have seen lots of electronics go bad. The main cause for this might the in the switch itself. Might have been corroded and shorting itself, therefore its like pushing the button on its own.
Lucky10R is offline
post #4 of 5 Old 05-08-2009, 03:46 PM Thread Starter
Drain Fade's Avatar
Just wanted to post up an update for anyone else tat may have similar problems. The new one is installed and it's perfect, I also set it to hard (I always run on hard) and covered the button. I ride all year round and condensation through the button hole was my problem I think. Fingers are crossed that this will be the fix and this one won't go bad. We'll see how it goes...otherwise I'm very happy now and so is the bike.
post #5 of 5 Old 05-08-2009, 05:59 PM
Lucky10R's Avatar
Images: 19
I like GiPro mainly for the tre, but the GI sucks big time.
At some certain times, I have been running on 6th gear, and it never showed 6, just 5.
And it takes about 1-2 seconds before the right gear shows up.
Lucky10R is offline
Help changing a map for TRE & BMC fordfasterr Performance and Tech 16 10-26-2006 09:56 AM
Changing oil in my 06 10r mikezx-10r The ZX-10R 13 06-09-2006 12:58 AM
Changing oil soon at 3K-Synthetic or not? steves87 The ZX-10R 20 06-04-2005 10:48 PM
