Getting tuned. Will GiTRe effect PC mapping? - Kawasaki ZX-10R.net
post #1 of 8 Old 04-18-2008, 06:32 AM Thread Starter
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
Getting tuned here in a few. Wondering if the GiPro with TRE will affect the PC3 and Ignition Combo I have? Meaning since the TRE messes with timing is it going to effect the tunning of my PC3 and Ignition Module? I was just curious tho b/c if it effects it negatively then since I did not install it (GiPro w/ TRE) yet I will just sell it.
Thanks
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
post #2 of 8 Old 04-18-2008, 12:43 PM
livefast's Avatar
Send a message via MSN to livefast
I am pretty sure the gipro only tells it it is in 5th or 6th gear so the secondaries open up faster I don't think it has anything to do with ignition timing. If anything, it would advance the timing not retard it. It will affect your air/fuel ratio though for tuning.
livefast is offline
post #3 of 8 Old 04-19-2008, 10:38 AM Thread Starter
OneSLOW10's Avatar
bump pigeons :)
post #4 of 8 Old 04-19-2008, 11:14 AM
blackbeast's Avatar
it all works well together
blackbeast is offline
post #5 of 8 Old 04-19-2008, 11:45 AM
Nukedog's Avatar
TRE's are used on many bikes when mapped or not. You will be fine...
09 R6S Slow and steady...
USN Retired *1987-2007*
IYAOYAS
Nukedog is offline
post #6 of 8 Old 04-19-2008, 12:04 PM
CMG
TRE's = Neutral not 5-6 th gear. see threads on here for proof/details
CMG is offline
post #7 of 8 Old 04-19-2008, 02:30 PM Thread Starter
OneSLOW10's Avatar
Thanks every one :)
post #8 of 8 Old 04-19-2008, 02:49 PM
livefast's Avatar
ivan's TRE = neutral, the gipro only on setting 1
view thread gipro what it really does
livefast is offline
what effect does a 190/55 have? RedNinja The ZX-10R 50 03-01-2007 06:27 AM
Does the TRE effect top speed??? T3MPO The ZX-10R 8 08-11-2006 01:00 AM
TRE Effect? ZX10Rip Performance and Tech 13 06-11-2006 08:45 PM
Effect of changing sprokets on torque graph CentBiker Performance and Tech 7 11-24-2004 09:19 AM
Going -1F - What effect on wheelies atkinsr The ZX-10R 7 10-20-2004 12:25 PM
