To get new brake rotors or not? - Kawasaki ZX-10R.net
post #1 of 10 Old 10-10-2010, 05:08 AM Thread Starter
ikaika's Avatar
Alright, I am sitting here in Afghanistan just thinking about what I need to do to my bike when I get back. I need new brake pads for sure but now I am thinking about getting new rotors, front and rear. I was looking at the Galfer wave rotors. Is it necessary to get new rotors. I am thinking along the lines of when you get new sprockets, you should get a new chain too. Will new brake pads seat in well on my old rotors? Should I get the old rotors resurfaced. Just a few things I was thinking about out here in the desert. Any input or advice would be greatly appreciated.
ikaika is offline
post #2 of 10 Old 10-10-2010, 09:06 AM
Rotor are not always needed when changing out pad. It is a if it ain't broke leave it alone item. Upgrading your brakelines would be worth while though. I'm sure if you don't need to replace them 500+ can be used somewhere elese.
parisdreams is offline
post #3 of 10 Old 10-10-2010, 09:40 AM
TROOPER's Avatar
^^what he said, rotors should not be needed unless you wore them down with bald pads. Kawi brakes are strong as is, upgrade to spieglers with carbon pads and you will be amazed. Take the $ saved on rotors and put it on other beneficial upgrades.
Oh and if ur military a big thanx for your service. Spread that to evryone you know, you guys are apreciated.
TROOPER is offline
post #4 of 10 Old 10-10-2010, 10:59 AM Thread Starter
ikaika's Avatar
Thanks for the info. I already have HEL brake lines and my brakes hold up just fine. I was just curious about the rotors. I can definitely find something better to spend $500 dollars on. Thanks again.
ikaika is offline
post #5 of 10 Old 10-13-2010, 01:26 AM
Newfie Bullet
craig_sez's Avatar
Images: 34
If you wanna do a lil trick i was once told about..Assumeing your rotors are 100% straight you can have them resurfaced sorta speak(more of a clean though) ..I dont remember exactly how its done but if memory is correct you use something like a circular type wire brush attachment to a drill and do a cross pattern all over both sides of each rotor...
Hopefully im explaining it correctly cause the idea is foggy in the ole brain...
NOw dont hold me to it or anything,lets wait and see what others say before you attempt this..
Its just something i was once told that basically scores the surface a smidge so pads bed in the right way..
I love to try these..http://www.braketech.com/index.php?o...50&It emid=95
IF you dont wanna or have ta spend the $$ stay stock and beef up calipers and pads..
craig_sez is offline
post #6 of 10 Old 10-13-2010, 02:03 AM
All show and all go 10r
JLG0987's Avatar
when I got just new pads they were fine. you don't need anything just come home and ride.
JLG0987 is offline
post #7 of 10 Old 10-13-2010, 02:40 AM
Licensed Dist of HaterAde
TMY10ER's Avatar
I have some 300mm brembo hp rotors for sale IF you're interested? as well as a pair of nissin zx14 calipers and some braided superbike lines that bolt directly into the calipers (not the lines pictured, these are silver)....but as stated above, the new pads will seat in just fine on used calipers.
https://www.zx-10r.net/forum/showthread.php?t=94929
TMY10ER is offline
post #8 of 10 Old 10-13-2010, 02:40 AM
TMY10ER's Avatar
...again, this is VERY true my friend!!!!!
TMY10ER is offline
post #9 of 10 Old 10-13-2010, 04:26 AM
jdgun_13's Avatar
Send a message via Yahoo to jdgun_13
yeah new pads, SBS sintered street work amazing...As for rotors, if you arent going to work this bike out on the track repeatedly with race compund pads than you are pretty much just spending money..as the galfer wave rotors are about 2 oz lighter each, but they can take way more abuse.
I use them on my 636, they sure look pretty...so how many days you haev left?
sitting on 136 here in Iraq..
jdgun_13 is offline
post #10 of 10 Old 10-13-2010, 06:11 AM Thread Starter
ikaika's Avatar
Man, we are about the same, I am sitting at 124. I dont go on R&R till March though. Anyways, I am just looking for a good replacement that is similiar to the OEM's. Those OEM's are pretty expensive. The SBS you recommend are pretty good?
ikaika is offline
FS 04-05 Stock Brake Rotors fireman69 Parts, Gear and Accessories 0 04-19-2010 03:28 PM
Front brake rotors turbo10 The ZX-10R 4 11-01-2008 09:57 AM
Need Price on Brake Tech Brake Rotors JimmyJam Vendor Deals 4 10-09-2008 12:14 PM
06 10R -- 06 14R brake rotors alteredZX-10 Performance and Tech 2 08-07-2008 04:32 PM
ZX-10R Brake Rotors - LIKE NEW JLove Parts, Gear and Accessories 0 03-20-2005 04:50 PM
