Generato gear - Kawasaki ZX-10R.net
post #1 of 8 Old 03-06-2010, 05:39 PM Thread Starter
rev
Generato gear
question answered
rev is offline
post #2 of 8 Old 03-06-2010, 05:57 PM
Judge Dredd Mod
mr_honez's Avatar
Can the gear be pulled off? There are quite a few highly knowledgeable people here who can help you. I just happen to be one that can't unfortunately. But I can the thread!
BURNOUT.....
mr_honez is offline
post #3 of 8 Old 03-06-2010, 06:11 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
Originally Posted by rev View Post
I dont think so it seems like its held together as one piece.
It's strange that the 05 will go into the 04 but not the otherway around...just with that i would thing there is a big enough difference to matter but to what extent i have no clue..sorry man
TMY10ER is offline
post #4 of 8 Old 03-07-2010, 11:49 PM
lenshead's Avatar
The generator gear is actually 2 gears separated by some kind of rubber pre-load offset. One gear has to be rotated slightly relative to the other, so that both gears will slide on to the clutch gear.
I did the 04-05 swap and this replacement was the biggest PITA EVER!
Like I posted once before, there is probably a right way to do this, but the way I did it must have been the wrong way. Like building a ship in a bottle, only with bloody knuckles! In retrospect, maybe it would have been easier if I had removed the clutch...
To answer the question, I don't know how critical it is to match the gears. I threw mine in and it worked.
TIP: when tightening the generator cover screws, do so a bit at a time and make sure you can still turn the crankshaft. The first time, my gears didn't match up right, and after I tightened the screws, my engine would not turn at all! Scary!
lenshead is offline
post #5 of 8 Old 03-09-2010, 10:18 AM
tasos's Avatar
It must be matched. Thing is all the crankcases of the 04-05 were not the same, so they had to make different cranks/clutches/generators to match them.
So by putting a wrong gear you risk a non100% fitment between the gears. And when a generator is granading is not a good thing. Not to mention they are the weak point of the 04-05's.
It is easy to swap it and is better to remove the clutch, it will be much easier.
Also note that between the 2 gears, there must be a gap of 0.6mm. If not, fillers are available from Kawi. I think i posted the part nos. in another thread somewhere.
Hope this helps.
tasos is offline
post #6 of 8 Old 03-10-2010, 12:42 AM
tasos's Avatar
I see what you mean.
I am assuming you have a 04 and you found a used 05 generator with another gear letter?
Is your 04 C gear destroyed?
I'll have a look and let you know...
tasos is offline
post #7 of 8 Old 03-11-2010, 04:51 AM
tasos's Avatar
no but it doesnt fit in the 05 generator
You are right, unfortunately it doesn't fit, you need a 04 generator.
tasos is offline
post #8 of 8 Old 03-11-2010, 07:53 AM
RussMcB's Avatar
I don't have the service manual in front of me, but it has charts regarding which parts will work together. It's a must read (if you haven't already).
I have an '04 generator for sale. It's not the later improved version, but I'll sell it cheap if it will help you.
RussMcB is offline
What gear you usually use Thure General Motorcycle Discussions 50 07-09-2008 08:45 PM
Race Gear / Riding Gear kawboy69 Parts, Gear and Accessories 8 05-17-2008 07:38 AM
Gear 08Black10r The Out House 18 04-10-2008 06:58 PM
636 1st Gear feels > 998 1st Gear ASIANPRIDE The ZX-10R 43 07-02-2007 12:11 PM
first gear Joe1233 The ZX-10R 34 08-16-2004 09:10 PM
