General Gasket Question - Kawasaki ZX-10R.net
post #1 of 14 Old 07-07-2010, 07:13 PM Thread Starter
alaywa's Avatar
Question General Gasket Question
Does one need to replace a gasket (for example for the oil pan) if one just removes it and puts it back on. No damage. 2009 ZX10R by the way, and a pain to get to cause of the exhaust pipes!
alaywa is offline
post #2 of 14 Old 07-07-2010, 07:20 PM
gazx10's Avatar
replace or not
fine to reuse if in good cond.
gazx10 is offline
post #3 of 14 Old 07-07-2010, 07:54 PM Thread Starter
alaywa's Avatar
sweet thanx!
alaywa is offline
post #4 of 14 Old 07-07-2010, 08:32 PM
sam_b03's Avatar
I have never broken a seal on my bike but rubber gaskets are easier to reuse than cork.
War is about killing people and breaking things. It ain't the olympics. Its not supposed to be fair. Tom Clancy
ialsodontknowwhynewpeoplecantseperatetheirthoghtss owecanreadthemitmakesitunweidlyandannoyingtryingto decipherwhattheyaretryingtosaysoiusuallyjustmoveon atleastyouusedpuncuationthoughsocongratsonthatbutm aybeinthefutureyoucanhelpusalloutbecauseyouoranyon eelsewillgetmorerepliesifyoudontwriteonebigrunonth atsimpossibletoread
sam_b03 is offline
post #5 of 14 Old 07-07-2010, 08:37 PM
I try to make a habit of not reusing paper gaskets. I am not sure what material the oil pan gasket is, but if a paper gasket gets saturated at any point it will be suspect to leak. I wouldn't risk trying to reuse a gasket that seals oil, especially that low on the motor.
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
HST
"Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" HST
abusfullofnuns is offline
post #6 of 14 Old 07-08-2010, 12:53 AM Thread Starter
alaywa's Avatar
Type of gasket
I think it's a metal gasket. Does that sound nuts? I'm pretty sure it's a metal gasket.
I've put the pant back together, and when my clutch cover comes in and I seal up the engine again and dump in some new oil I'll update and let you all know if the pan gasket held up.
alaywa is offline
post #7 of 14 Old 07-08-2010, 10:43 AM
Lougots's Avatar
Except for covers with rubber gaskets or o-rings that are meant to be taken off and replaced frequently for routine maintenance, I always replace the gaskets. It really sucks to put it all back together and have a leak.
Green '04
Lougots is offline
post #8 of 14 Old 07-08-2010, 11:12 AM
gazx10's Avatar
gaskets
composition gaskets are fine to reuse also if in good cond. and cleaned properly. they dont start leaking just because you removed them. removing and installing covers carefully is the key. even a lightly damaged composition gasket can be reused with certain sealers, also with certain sealers u dont even need a gasket and it will not leak! btw, there are no paper or cork gaskets on ur 10, and yes both would saturate and leak. most leaks are our fault, not the gaskets.
gazx10 is offline
post #9 of 14 Old 07-08-2010, 01:54 PM
ducatiryder89's Avatar
Images: 21
Why bother. For the few dollars having piece of mind that you have a new gasket in there as opposed to spending another couple hours to change it if it happens to leak. Time is money. Gasket is less then $50 while your time is priceless. Every single gasket if I remove I replace with a new one. But that 's just my opinion.
2005 ZX10R Track Bike With Way To Much Sh*t On It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ducatiryder89 is offline
post #10 of 14 Old 07-08-2010, 04:00 PM
Really, Even with rubber gaskets that stand a chance of working (compressing right), I don't know (well I do know paper/cork is a one shot deal) what the casket condition will be, before the job is started.
So having the gaskets needed before the job starts, is just the way.
Anyone want to take the extra time to get a needed gasket, when they find out a gasket isn't going to make it a second time? Wow that's so expensive and time consuming...it's just off the chart.
louemc is offline
General hp question? kmg300 The ZX-10R 18 02-27-2009 03:27 PM
General race rep seating position question 06wreckedzx10 General Motorcycle Discussions 1 12-14-2008 09:13 AM
General question please>. blackisfaster The Out House 11 09-08-2006 11:20 AM
Gasket question jjgi550 Performance and Tech 9 02-27-2005 02:02 PM
general tech question Ricci The Out House 0 05-17-2004 01:37 PM
