GEN5 crankcase breather question - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By michael4012
  • 1 Post By theatiss
post #1 of 6 Old 03-20-2019, 04:19 PM Thread Starter
Question GEN5 crankcase breather question
Hi guys, sorry but I couldn't find a reliable info on this so I'm asking.
I've done the pair valve mod on my zx10 gen5 and I've also plugged the airbox hole from the crankcase breather as you can see on this pic :
What should I do with this hose ?
Some people speak about a catch can, some about adding a filter, some about routing it back to the intake ?
Will it spit oil ? Doesn't it have a one way valve before ?
Thanks.
Arkama is offline
post #2 of 6 Old 03-20-2019, 04:21 PM Thread Starter
Arkama is offline
post #3 of 6 Old 03-20-2019, 04:36 PM
michael4012's Avatar
Depending on the condition and use of your engine it may or may not puck oil out the breather due to blowby in the cylinders, catch tanks were designed so oil doesn't spew out onto the track. If you fit a crankcase breather filter to the tube or a modded tube it allows the crankcase to breath as it wishes but if your getting puking once the tube and filter fills up oil will spew on the track or road. Depending on your usage you may be better leaving it plumbed into the airbox that can also fill with oil if your puking oil. Or you could just run a pipe tp the reed valves and run the crankcase at negative pressure and excessive puking will just get blown out the exhaust onto track or road. Probably better you tell us what you do with your bike.
michael4012 is offline
post #4 of 6 Old 03-20-2019, 04:47 PM Thread Starter
It's mainly a streetbike
Arkama is offline
post #5 of 6 Old 03-20-2019, 11:10 PM
Well its probably best to leave it plumbed into the airbox and occasionaly check the end of the drain pipe for signs oil has come out, if so whip the airbox cover off and see its all out. The next to zero power gain you get from re routing the breather is just not worth trouble for a street bike, and the odds of puking are minimal. Thats my opinion.
gaz likes this.
post #6 of 6 Old 03-21-2019, 01:40 AM
theatiss's Avatar
If its a streetbike u better just let it plumbed into the airbox... I have done it to my gen3 zx10r and i think is just not worth it....Go back to stock settings lololololol
gaz likes this.
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
Gen 2: Crankcase breather re-route? TexasRider Performance and Tech 10 03-20-2019 04:27 PM
Gen 1: Where to re-route crankcase breather out of airbox. WildB302 Performance and Tech 0 04-26-2012 07:59 AM
Gen 2: Fuel Tank Breather / Gas Leaking Squidward Performance and Tech 3 04-10-2012 04:48 PM
WTB 04 ZX10R Breather Mounting Bracket okhaze Wanted: Buy or Trade 0 03-15-2008 05:48 PM
Engine breather johnny napalm Performance and Tech 8 03-27-2007 06:07 PM
