Gen4 ABS Removal - Kawasaki ZX-10R.net
post #1 of 5 Old 07-11-2014, 06:05 AM Thread Starter
Gen4 ABS Removal
So I've got a 2012 ZX10 ABS and have bypassed the ABS unit but i'd like to actually remove it.
Does anyone know how this can be done? is it a case of non-abs wiring loom or wat is required?
kordo is offline
post #2 of 5 Old 07-11-2014, 06:25 AM
Tech5's Avatar
If I can add this to my bike I would buy everything
Any know if you can add this ?
Tech5 is offline
post #3 of 5 Old 07-11-2014, 07:54 AM
Kordo; You have to leave the ABS control unit plugged in, otherwise the bike will not rev over like 10,000 rpm, and you will have other problems. The only way you can remove the control unit is to replace the entire bike wiring harness with one from a non ABS model. Mike.
880turbo is offline
post #4 of 5 Old 07-12-2014, 03:40 AM Thread Starter
well i'm looking to race loom it and am planning on buying a new loom... so if the entire loom it changed for a non-abs model will it work? or will the dash/ecu throw codes
kordo is offline
post #5 of 5 Old 07-12-2014, 11:36 AM
Shorty's Performance
madnessracing's Avatar
I took everything off my 2013 zx14r and everything works perfectly fine, the engine works and performs perfectly fine.
madnessracing is offline
Gen 4: abs removal stangs10rnkc The ZX-10R 105 11-19-2018 02:40 AM
Should I have bought an abs instead of a non abs gen4? tyto17 The ZX-10R 47 03-28-2014 09:18 PM
Gen 4: Gen 4 abs sensor removal 504boy The ZX-10R 9 10-07-2013 09:21 PM
Gen4 Abs Porhot The ZX-10R 24 05-05-2012 12:10 AM
GEN4: ABS brake lines - modulator fitting Exup Performance and Tech 8 01-08-2012 05:57 AM
