Gen3 sidewinder install - Kawasaki ZX-10R.net
 3Likes
post #1 of 14 Old 01-26-2019, 04:56 PM Thread Starter
I recently bought a sidewinder for my gen 3 dragbike but it’s hitting the oil cooler and filter mount.
Anybody have experience with this install and how to avoid the interference?
'08 10R, Lime/Black
Flashed ECU, PC5,WBC, custom shift light, shifter w/co2, side winder, BMC race, lowered, stretched,-2/+4, velocity stacks, little spray, nos mini.....
MORE TO COME
medicbaldwin is offline
post #2 of 14 Old 01-26-2019, 06:02 PM
gaz
some hit the outside bolt on the oil cooler, they grind it down . more than that?
gaz is online now
post #3 of 14 Old 01-27-2019, 10:37 AM Thread Starter
I’d need to completely grind off the outside ear?
michael4012 likes this.
'08 10R, Lime/Black
MORE TO COME
post #4 of 14 Old 01-31-2019, 06:45 AM Thread Starter
Been looking into an oil filter relocation kit, any recommendations on this? I'm sure either remote mounted or mounted the other direction would clear.
'08 10R, Lime/Black
MORE TO COME
post #5 of 14 Old 01-31-2019, 08:12 AM
gaz
u hitting the oil cooler, filter or just everything? adams has a oil adapter filter for the zx14, does away with the oil cooler which u can do without. have to plug couple or radiator lines no problem to do.$129. also filter mount appears shorter. schnitz states thier kit fits all years zx14, zx12, zx10, so should work. call them.
ddipaola likes this.
gaz is online now
post #6 of 14 Old 02-01-2019, 11:21 PM Thread Starter
I may have found a solution to the oil filter and cooler problem.
I removed the cooler and pulled the filter mounting bracket off. Looking at I thought, why can’t I just turn this upside down?
I matched it up and the bolts thread in. The oil ports are like a tilted figure 8, which they appear to line up as well.
Anybody see a reason this would not work?
'08 10R, Lime/Black
MORE TO COME
post #7 of 14 Old 02-01-2019, 11:23 PM Thread Starter
Here’s the base plate upside down with cooler removed
ID:	420881   Click image for larger version
'08 10R, Lime/Black
MORE TO COME
post #8 of 14 Old 02-02-2019, 01:03 AM
thundercoupe9's Avatar
I don't think that oil filter will work very good backwards.
thundercoupe9 is offline
post #9 of 14 Old 02-02-2019, 10:50 AM Thread Starter
Would it change direction of flow and not actually work or just not line up?
'08 10R, Lime/Black
MORE TO COME
post #10 of 14 Old 02-02-2019, 01:24 PM
Most spin on oil filters are flow directional, that means that they will not work regardless if it lines up or not.
Gen3 Shogun "cut" frame slider install. JUICEBOX General Motorcycle Discussions 22 03-27-2014 11:41 PM
Gen3 ZX10R XTRE Install Dingus The ZX-10R 5 05-08-2013 08:29 PM
Gen3 ZX10R Block off plates install Dingus Performance and Tech 6 08-23-2012 05:12 PM
Parting Gen3 Engine and other GEN3 Parts Saleen114 Parts, Gear and Accessories 28 08-11-2011 10:59 AM
Euro Install: Easiest Way to Re-install Inner Liner Under Headlight? IcePick06 Performance and Tech 18 12-30-2005 10:52 PM
