Gen3 & Gen4 Caliper Upgrade - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By theatiss
  • 1 Post By ukzx10r
post #1 of 6 Old 08-30-2018, 03:19 AM Thread Starter
ZX-10R_04's Avatar
Years ago I upgraded my Gen1 to the awesome Nissin calipers from a ZX14 or ZX6R .. Massive night & day difference as some of you would know , Always wanted to upgrade my Gen3 to some great Nissin's ... Advantage Nissin calipers cost about the same amount as the Brembo's but yes in link shows other Calipers that will fit ... Tried the Triumph Daytona 675 2012 calipers & The Suzuki B-King & yes both are much better than stock 08-15 ZX10R calipers Daytona Calipers need shorter caliper bolts , B -King direct swap same caliper bolts
B-King seems to be the best choice
ID:	419569   Click image for larger version
Bmc filter, Hels Braided Brake lines, Nissin ZX14 Calipers, Brembo, RCS19 M/C, Ohlins damper,Fender Eliminator, Puig screen, Smoke Integrated taillight, Green front indicator lens's, Mirror block plates, Gauge Mod, Vortex rear sets, Personalized # Plate, Pazzo levers, 1/5th Throttle insert, H.I.D Headlights 5000k, Seat cowl, Gen 3 Swingarm, Titanium exhaust hanger , Racefit Growler ,GIpro TRE , Michelin pilot pures, -1 front sprocket, PCIII, SpeedoHealer v4, Factory Pro V Stacks
ZX-10R_04 is offline
post #2 of 6 Old 08-30-2018, 04:32 AM
michael4012's Avatar
I totally agree, i have ZZR14 2010 calipers on a Gen3, as you say the difference was night & day, I then added the RCS19 master cylinder, that also improved outright braking further.
michael4012 is offline
post #3 of 6 Old 08-30-2018, 08:45 AM
bun1t's Avatar
I had the Nissin Monobloc calipers on my Gen 4 and took them off after one track day. They had too much pad drag and when the front wheel would lift, the traction control would cut power right away causing me to pogo stick down the straightaways even in TC1. I tried a couple other pairs and had the same results. The Nissins just don't seem to work well for bikes with Traction Control.
bun1t is offline
post #4 of 6 Old 08-30-2018, 08:54 AM
Formerly CLCRACINGAaron
Neonmarine's Avatar
I think an OEM set of M50's will fit...
"You must subsume yourself to the bike"-Casey Stoner
"There’s a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #5 of 6 Old 08-31-2018, 01:06 AM
theatiss's Avatar
I have Honda fireblade calipers....OOOooooopssssssss i said Honda..These calipers are equal as K9 suzuki and zx14. I also have a Accossato billet master cylinder. Difference is as da and night
michael4012 likes this.
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
post #6 of 6 Old 08-31-2018, 11:36 PM
I got r1m calipers. No better than standard really but look better and weigh less.
ukzx10r is offline
Gen4: Gen3 rims on Gen4, anyone here done it? Joel The ZX-10R 11 06-04-2015 12:57 PM
Brake upgrade ! best upgrade so far! Simonvez The ZX-10R 2 07-22-2013 03:55 AM
ZX6R/ZX14R Nissin Caliper Upgrade is a must!!!! prboarder The ZX-10R 39 03-09-2011 09:32 AM
ZX14 Caliper Upgrade - M/C question anaxdlere The ZX-10R 9 03-13-2010 01:14 AM
Rear Brake Caliper Upgrade evan_880 Performance and Tech 7 08-23-2008 11:25 AM
