Gen 1: 2004-2005 Gen3 ECU on Gen1 - Kawasaki ZX-10R.net
post #1 of 6 Old 10-23-2014, 10:47 PM Thread Starter
alikuka's Avatar
Question Gen3 ECU on Gen1
hello everybody. I need some help from of competent people.I bought 04 zx10r with A&A performance supercharger, how everybody knows, 04 zx10r do not have secondary fuel injectors, so i want change ECU and put there from 08 zx10r, because I think on high rpm not enough fuel and the engine runs on a poor mixture. is it possible put there 08 zx10r ECU? is GEN 1 sensors voltage same as GEN3? thanks for the help in advance!!
alikuka is offline
post #2 of 6 Old 10-23-2014, 10:54 PM
bluedevil's Avatar
Maybe Garth will Chime in because he asked me that question before in a PM because of my electronic experience even though he has much more motor experience and in the end after his research not going to happen on a 1st Gen...
with that said with new ECU programming available who knows....I am jealous though you got the A&A supercharger....let me know if you ever want to get rid of it but doubt it.
Bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #3 of 6 Old 10-24-2014, 02:12 AM
this might give some clues http://gravelrash.com/2008-zx10r-rac...on-2006-zx10r/ hope it helps.
ZX10RKANGO is offline
post #4 of 6 Old 10-24-2014, 11:28 AM
gazx10's Avatar
know dsbat's gen 2 zx10 turbo supported 430 hp with a walbro 255 fuel pump and larger single injectors tuned by my tuner with a pc3. stk. injectors with a good pump will support about 270 before maxing duty cycle out. poor mixture, that's tuner only. i would keep it simple, works better a lot of the time.
gazx10 is offline
post #5 of 6 Old 10-24-2014, 08:55 PM
thundercoupe9's Avatar
Put a stand alone ecu on the bike and call it a day. You can run 4 injectors, you can run 8 injectors, you can do pretty much anything you want, pump gas, e85, race gas, closed loop, run water/meth kit, adjust for elevation.......and more.
thundercoupe9 is offline
post #6 of 6 Old 10-24-2014, 09:05 PM
tyler.nd@hotmail.com's Avatar
Gen3 ECU on Gen1
U can make more then enough as previously said on stock injectors or upgraded no need to switch ecu and if u make any more power gonna need to balance crank as number 4 piston will eventually let go on you also that super charger is only good for 25-30 sec full throttle burst can't handle heat etc after that and low compression Pistons ,rods ,new pulley can run 13psi ,water/meth
Also you can contact Dave from A&a and he will also give advice there is also ther member on here running 13psi with fully done motor
I have A&a kit that was piced together from member but I also contacted Dave n got all parts n specs for parts etc and mine is a 1051 overbore with low comp Pistons etc ,rods ,water meth list goes on
Gen 3: Gen2 ECU vs Gen3 ECU pallykuo Performance and Tech 5 11-16-2012 05:48 AM
gen3 to gen1 ghw1972 The ZX-10R 16 05-21-2012 08:09 AM
Anyone with a gen1 AND gen3? NinjeR The ZX-10R 3 03-04-2011 01:02 PM
gen1 vs gen3 mdenari The ZX-10R 16 11-14-2010 05:58 PM
Gen1 to gen3 duckcall The ZX-10R 6 06-27-2010 11:33 PM
