Gen1 Power Commander 5 - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By gaz
post #1 of 7 Old 01-04-2019, 04:52 PM Thread Starter
Anyone that could offer me some help on this id greatly appreciate it.....
I'm trying to get the gear position indicator to work with my power commander 5 and in doing so the instruction say that i need to send a signal to the PC5 from the Speed Sensor input wire.
I have no idea where such wire is located, could anyone please tell me??? Thank You for any help in advanced.
Padlock572 is offline
post #2 of 7 Old 01-05-2019, 08:23 AM
gaz
speed sensor is located on outside sprocket cover on gen 1.
gaz is offline
post #3 of 7 Old 01-05-2019, 09:25 AM Thread Starter
Thank You, I’m aware of where the actual speed sensor is. More specifically I’m trying to find out exactly which wire I’m suppose to be tapping into in order to get that signal to my PC5. I have the DynoJet POD300 display module and I’m trying to get it to display Speed, and Gear position.
post #4 of 7 Old 01-05-2019, 09:39 AM
gaz
your speed sensor 2 or three wire?
gaz is offline
post #5 of 7 Old 01-05-2019, 11:43 AM Thread Starter
It’s three wire. Black, yellow, and either pink or faded red
post #6 of 7 Old 01-05-2019, 12:47 PM
gaz
try to help. go to perf section on this site, pull up 04-05 service manual. under fuel injection section 3-66/3-67 describe speed sensor volt input and rising volt tests. voltage meter set at 20v dc verify input voltage 9-11 volts probing +probe into pink wire/neg probe into black wire. sure ur ok here as speedometer working. to check for rising rate voltage(signal wire) manual says probe neg meter probe into blk wire and +probe into blue/yellowstripe. u have no b/ys wire, later models did, but process of elimination(pink is input voltage/blk is ground) says the yellow wire is correct signal wire. to confirm probe the yellow wire + probe/neg probe to black wire, sprocket stationary should get reading .05-.07v. rotating wheel off ground will produce a voltage increase. what ur looking for much like tps rising rate signal when u twist throttle. grounding the meter - probe to any good ground will work as with vise grips and make probing the other yellow and pink wires easier to ck. whichever shows volt increase with wheel/sprocket rotation is signal wire. dc volt/ohm meter about $15 at parts store if u lack one.
michael4012 likes this.
gaz is offline
post #7 of 7 Old 01-07-2019, 09:57 AM Thread Starter
Thank You very much for your help i will try this and see what the outcome is.
Gen 1: Selling power commander gen1 in great condition! $175+8.75 shipping rideordie36 Parts, Gear and Accessories 4 04-02-2013 04:59 PM
power commander gen1 blacksonne19 Wanted: Buy or Trade 0 04-24-2012 11:45 AM
Gen1 wtb used power commander/ign mod [email protected] Wanted: Buy or Trade 1 03-07-2012 04:23 PM
Gen1 power commander and full exhaust/headpipe Time1 Wanted: Buy or Trade 1 10-22-2011 12:20 PM
gen1 power commander m6rk The ZX-10R 4 02-22-2010 09:44 AM
